You poor thing, my heart bleeds for you
Could be worse. Our meander through France is turning into a gallop South to find some sun. Mud is no gud.Looks like it's getting cooler this week , I might have to dig out my jumpersView attachment 900711
I've always found French weather to be similar to the UK.Could be worse. Our meander through France is turning into a gallop South to find some sun. Mud is no gud.
He's moved now and parked over by the herd .If he dumps his grey on the carpark it will wash you away.![]()
Probably was warned you might try to sell him some melonsHe's moved now and parked over by the herd .
Snob
Yeah but no room in the freezer. I've a couple of dorados in there aswell as ice cubes and some bolognese leftovers.Tam, google can you freeze water melon? you can![]()
I was just reading the first 10/12 pages of my first trip to Spain. Jees how life was different then , no dogs , massive van ...
A lot of members no longer with us though for whatever reason .
Yes I imagine so ... they seem to remember everyone they've metYou had only recently got Jade when I met you in France… do you think she’ll remember me when you visit…![]()
Living the dreamHad a look around methoni today .. Nice day for the drone.
Not camper friendly at this time of year though so we had to move on afterwards View attachment 901320View attachment 901321View attachment 901322View attachment 901323View attachment 901324View attachment 901325View attachment 901326View attachment 901327View attachment 901328View attachment 901329
yes, I read it too up until you adopted Jade and I loved it. I was so interested in your life before dogs, it was so much better afterwards in my opinionI was just reading the first 10/12 pages of my first trip to Spain. Jees how life was different then , no dogs , massive van ...
There's only 2 carparks , both have signs stating no parking of motorhomes after 20.00 hours. Can't park at pylos , gialova or voidokilia either . Winter is different same as Spain etc . But now the tourists are here the police become assholes.Tam
Why Methoni not user friendly and had to move on?
Do you think it would be same in September?
Geoff
The floor on this van is a crazy construction. It's basically a 40mm slab of polystyrene which has a thin 4mm sheet of ply top and bottom . The bottom has obviously got damp/soft over the years. The worst area being directly above the rear wheels which us the area between fridge and wardrobe , problem now is because its been spongy the top plywood has now cracked and split. The only thing keeping it together is the linoleum. Will have to try and put a bit heavier ply on the underside between the wheels and brace it somehow. And then I'll need to put something more substantial over the floor inside , maybe 6mm ply and new linoleum. . Or laminate flooring or something.Your photos are ok, once again, Tam. I've been thinking about your spongy floor, and maybe it needs injecting, in the bad area, with the stuff that's made for caravan floors that are delaminating. Maybe you could investigate what the problem is and then come to a decision regarding the new floor covering you are considering. Perhaps it needs an area cutting up and sorted! Its not a big deal for me and you shouldn't worry about it. Keep up the good work and good luck
Actually having typed that I think the best way would be to cut 6mm ply to fit between the floor supports and put it over the entire middle section underneath. Then put 6mm ply over the floor inside and screw it down catching the ply underneath too which would sandwich the lot and should then be very strong. Then just put new floor vinyl down inside and bobs yer grannies aunty.The floor on this van is a crazy construction. It's basically a 40mm slab of polystyrene which has a thin 4mm sheet of ply top and bottom . The bottom has obviously got damp/soft over the years. The worst area being directly above the rear wheels which us the area between fridge and wardrobe , problem now is because its been spongy the top plywood has now cracked and split. The only thing keeping it together is the linoleum. Will have to try and put a bit heavier ply on the underside between the wheels and brace it somehow. And then I'll need to put something more substantial over the floor inside , maybe 6mm ply and new linoleum. . Or laminate flooring or something.
Basically it has a galvanised frame underneath that bolts the body to the chassis . To replace the entire floor would be a mammoth task and as I only walk on the middle section I figured if I just put ply up the middle underneath , bond it with sikaflex and then screw down from above it should sort it out. The insulation is just a big slab of polystyrene... its just moving because the wood underneath it is knackered. Hard to describe you really need to see itOk. I take it these floor supports are underneath the vehicle. Has the insulation deteriorated too? I will think it over during the day.
Perhaps talk to the Tavern - see if they are happy for you to stay [courtesy & all that] ?Would you go and talk to the frenchies and Germans? Or just leave it.
