- Aug 18, 2014
- 26,316
- 159,648
- Transit PVC
- 16 years since restarting
ebay it.Fetch good money.The tail lift is off, blimey that was heavy, and the towbar is on it's place.
I m following this thread with great interest, so thanks for keeping it updated.Bit more done. The roof insulation is in.
I've used recycled plastic, and then a layer of foil bubble wrapView attachment 482739
This is what I've used behind the foil, https://www.diy.com/departments/diall-insulation-roll-l-6m-w-0-37m-t-100mm/3663602481812_BQ.prdI m following this thread with great interest, so thanks for keeping it updated.
Recycled plastic behind the layer of bubble wrap? In what form does the recycled plastic come and where do you get it from?
I've seen that type of bubble wrap on eBay. Is that where you got it from?
Are you keeping a running total of the costs of the rebuild?
When you get there, it will be interesting to see the final figure.
Thanks for that. Every bit of information is always of help to someone...especially me lolThis is what I've used behind the foil, https://www.diy.com/departments/diall-insulation-roll-l-6m-w-0-37m-t-100mm/3663602481812_BQ.prd
It's stuck in place with double sided tape, and then the foil is fixed with spray glue, and the seams sealed up with aluminium tape. The foil wrap came from Toolstation, but lots of places sell it.
I'm not keeping a list of what I've spent, but I've spent about £750 so far. That's not for everything that's on the van, as some of it isn't fitted yet. I don't have a fixed budget, but I'm trying to keep costs down where possible. A fridge will be the most expensive bit. An awning is the other thing that I'm trying to decide on, but I don't fancy paying over £500 for a big wind out Fiamma, so instead I may add a C channel and use a caravanstore instead.
The foil works as a vapour barrier. Although you can't see from the photos, it's completely sealed in the section above the windows extending to the roof, and then again on the bits along the bottomThanks for that. Every bit of information is always of help to someone...especially me lol
I wouldn't fancy spending £500 on a wind out awning either.
Does a waterproof membrane have to be fitted at some point? Or have I missed that earlier in this thread?
I see what you mean, thanks for thatThe foil works as a vapour barrier. Although you can't see from the photos, it's completely sealed in the section above the windows extending to the roof, and then again on the bits along the bottom
No bubbles? They do make a massive difference to the look of the camper.The windows on one side are now tinted, which was easier than expected.
Just need to do the other side.View attachment 482869
Im 52, and can drive it. But I was looking ont the downrating thing as Im not sure of how it all works.Nice apart from the weight or are you older?!
I see that lt46 minibus can be downrarted. So I guess that could be too.
Cheers James
That's what I use,,Excellent awnings and quick to put up.BUSBY.This is what I've used behind the foil, https://www.diy.com/departments/diall-insulation-roll-l-6m-w-0-37m-t-100mm/3663602481812_BQ.prd
+1Wished I had the skills and the youth to do it
looking great and coming along nicelyI now have a bit of a floor to go with my ceiling. All I need to do now is fill the bit inbetween!View attachment 487676View attachment 487677
Thanks for answering my questions re the heater and the fixing of the wood.The timber cladding is attached to wooden batons which are attached across the roof space to metal bracing bars which were part of the roof structure when it was a minibus.
I went for wood just because we like the way it looks. There's plenty of options, just down to personal choice. That's the great thing about doing your own.
The heater was from a company called maxspeedrods, or something like that.
Today the wife did a bit and put a clear varnish on the ceiling.
I've also started to wire up the split charger and leisure batteries.
The plan is to use the van to take our daughters boat to a sailing event on Saturday. We'll be sat in the back watching from garden chairs! Lol
