Northernraider
- Jul 30, 2017
- 34,320
- 250,410
- N&B Flair 8000ib
- AirOn and off since 95
Id have to pull that dent out on roof or it would drive me nuts
Im considering it as you get a tintable one so can make it any colour.Do the full body on it mate raptor smooth looks great and a tough as old nails. Fantastic stuff covers light imperfections easy![]()
Looks amazing did you spray it or brush it?Bit more painting done, hope to have it finished by Sunday.
Hi JamesLooks amazing did you spray it or brush it?
Cheers James
Yes I used the proper silkaflex.I see you used plastic mounts for the panels I you used the correct grade of Stika as it is important you use the correct one on plastic.
I might have missed it, but what make of paint did you use for this undercoat please?Hi James
I'm doing it with a roller and brush
Best of luck with the conversion.Yes it's a step. There's no sliding door, so that's the way in. Not as handy as a sliding door, but gives more room to use.
This is the paint that I usedI might have missed it, but what make of paint did you use for this undercoat please?
Is it just normal grey primer, or is it something more hard wearing and longer lasting than just 'normal'?
It's not primer, it's just that it has a satin finish.Are you keeping the primer as top coat??
Cheers James
thanks for that.This is the paint that I used
Military Vehicle Enamel Paint | Military Paint | paints4trade.com
A high quality refinishing camo paint for military vehicles, commercial vehicles, army vehicles. All colours available. Call 0845 838 2225.www.paints4trade.com
There's 2 coats.thanks for that.
Considering that you are just using a roller and brush to paint it on, the finish isn't too bad at all.
Is your latest pic just one coat, or is there a couple of coats on there?
Bit flat for my liking but I can see how it works.
Thanks for thatThere's 2 coats.
Satin tends to work a bit better using the roller method. It would of been nice to have a proper respray, but I'm guessing I'd of been needing at least 2k, whereas all this cost was about £80 all in
Will be interesting to see how you progress, any idea what you are going to use for insulation.Over the next few months I hope to share with you the details as I transform a 2004 ExVariety Club 17 seater minibus into a motorhome. The base vehicle is 2004 Iveco Daily 40C13 fitted with a 2.8 engine, having covered 84,000 miles.
It's being delivered at some point this week, so I hope to make a start at the weekend.
I'll mostly be used recycle plastic insulation, as there's no concern about it taking moisture in, although I'll be adding a vapour barrier too.Will be interesting to see how you progress, any idea what you are going to use for insulation.
I've not driven it loads, mainly for picking stuff up. It's surprising how small a piece of 8x4 looks in the back of it! lolLooking good!
Missing a good project!
Have you driven it much yet?
There is a lwb iveco round the corner from me low mileage, god body / engine.
How do you find it drives? It's only .4m longer than my movano but seems like a whole lot more!
D day for my movano tomorrow got to find out what the garage are able to do with the engine.
Cheers James
To be honest I'm happy for someone to just take it away!How much do you think you will get for the wheelchair lift/ramp?
