£210 a corner at CostcoOnly 116 and 118… must admit, I am not thinking Michelin for next set either … I got a bit carried away with price - £253 and £257 - still steep b7t not quite £275
Is that for the Camping cross climates or the regular cross climates ?£210 a corner at Costco
Thats the regular van tyres. Have them fitted on my current MH and had them on the previous one.Is that for the Camping cross climates or the regular cross climates ?
I was quoting Camping tyre prices … I agree Van versions are much cheaperThats the regular van tyres. Have them fitted on my current MH and had them on the previous one.
Thats about the price I paid in November at Costco. Looking at your image, the van tyres have a higher weight loading .I was quoting Camping tyre prices … I agree Van versions are much cheaper£219 less 15% at Blackcircles makes them £186 fully fitted
That’s not bad a tenner a tyre for fourMichelin have a promotion too: https://www.michelin.co.uk/auto/promotions-michelin/auto
That looks like a very good price… and yes, I think that’s Continentals stiffer sidewall camping tyreHi Ernesto
Do you mean this tyre, have you seen This Deal 15% off when you buy 4 tyres?
The tyres are quoted at 116 on the original advert, don't know if you need higher rating than that.
LES
Is it Buy one get one free fro Twin Rear Wheel models?£210 a corner at Costco
Thats the compromise we all face unfortunately.This thread came about when I was mulling over my tyres in Germany they should only be on for 5years and although mine aren’t worn i Was thinking of replacing with michelin cp the same as before , I hate the harsh ride but I could have crossclimates cp £205 inc vat but they will have the strong sidewalls will this give the same harsh ride?can anyone help.
This is all good advice ...the only thing I would add is that there does seem to be a difference between tyre manufacturers. Michelin parrot the EU guidance and resolutely stick to recommending the maximum pressures for their CP tyres (80psi rear).Thats the compromise we all face unfortunately.
CP tyres have stiff sidewalls as our vans are always heavy, and are stored for a long time between trips.
Normal van tyres are not sat in one position for long as they are probably used daily and are loaded/unloaded and will probably wear out well before the 5 year lifetime.
Many Funsters have changed over to normal van tyres and have been much happier with the softer ride they offer due to the not so stiff sidewalls.
How long they will last on a van being stored over a length of time, is a risk that needs weighing up, and only the user can make that choice. This is especially important for those that don't use their vans over the winter, or store them for months of time due to work or other commitments.
No doubt we will hear both good & bad opinions on various tyres, from different people, on different vans, with different load ratings, some are happy with their choice, some have experienced premature cracking on both tread and sidewalls.
Its always a gamble, there is no substitute for experience, preferably your own.
Good luck with your eventual decision.
LES
Michelin say 80 rear 65 front, I run ours at 62 front 72 rear.This is all good advice ...the only thing I would add is that there does seem to be a difference between tyre manufacturers. Michelin parrot the EU guidance and resolutely stick to recommending the maximum pressures for their CP tyres (80psi rear).
Continental seem to take a different approach and if you dont plan on overloading your van, they will recommend lower pressures (65psi rear) - which even on a CP rated tyre, must be more comfortable?. And this is important as you should really run tyre pressure as recommended by your tyre manufacturer.
I was hoping someone with Continental CP tyres at the lower pressures could comment on this?
I agree .... the only reason I have found, is if you plan on regularly overloading your van. Rather than educate the owners that may make this mistake, Michelin and ETRTO have decided its better to force all customers to inflate to 80psi.I run ours at 55psi front, 70psi rear.
The strange thing is with Michelin, it looks like the load capacity is achieved at 475KPA which is 69PSI.
If that is the case, why would you need to use 80PSI?
Sorry for the confusion - mine are Michelin set at 55/70 psi.So how is the ride at 70/55 on Conti CP tyres?
Yes, that is the problem. The manufactures just quote the highest possible pressure even if it isn't required.I am somewhat confused about why you are blaming the tyre manufacturers for the recommended pressures. It is the van manufacturer that states tyre pressures for the vehicle depending on load. They are the same for all tyre brands.
I maybe wrong about this so very happy to be corrected but its because there are two manufacturers - Fiat and Adria.I am somewhat confused about why you are blaming the tyre manufacturers for the recommended pressures. It is the van manufacturer that states tyre pressures for the vehicle depending on size and load. They are the same for all tyre brands.![]()
