GPW
Yes less downforce and therefore less grip.
I had two scooters with identical rear tyres, it was always the smaller one that wore out the rear (driving) tyres faster - I put that down to the smoothness of the takeup (clutch) on the larger one.
ETA: I tend to run tyres on scooters and bikes to the exact specs, but on cars and van I usually run a few PSI higher - which is I expect the end result of Continental advice over Michelin.
I do this because:
1. A slow puncture or neglect in autumn keeps you above a safe pressure for longer. I note that Peugeot Boxers now seem to come with free tyre monitoring alarms - probably driven from the ABS ECU (so free to them and useful to us).
2. It saves fuel
3. More resistant to aquaplaning
4. Keeps the tyre cooler (less derformation)
The cost of over-inflation is slightly less grip in marginal conditions and wear toward the middle of the tyre but in practice running cars ar say 36psi instead of 28psi I haven't noticed any difference.
I always remember the Ford 'Exploder' in the US that had dodgy suspension so they were forced to run the Firestones at a reduced pressure. The recommended pressure ended up so close to the 'too low it will overheat' threashold that many cars had heat related blowouts.
The other side of the coin of course is if you go over the manufacturers max pressure ever (whch I don't!) you may get a spectacular blowout - for instance a Skip lorry tyre sits at around 100psi and it's like an explosion if they let go!
I do this because:
2. It saves fuel
