They are hinges aren't they?What are those bits that look like hinges under the backlights ?
I'm sure Tam said there was no back door ?They are hinges aren't they?
Look like the original rear door hinges?What are those bits that look like hinges under the backlights ?
That masking tape is never going to hold it.
No where to put one unfortunatelyTam, will you make a bed up permanently in your “winter” van? I was just wondering if putting in a bed mattress might be more comfortable than jigsaw cushions?
No back door now but will have been originally ..theyve just left the bottom hinges in placeI'm sure Tam said there was no back door ?
Don’t you have the back seating area and side seats at the front?No where to put one unfortunately
It has a small seating area at the back but when made to a bed you can't get in the toilet compartment. I also plan to put the pull out bit and extra cushions in the loft as i wont use them ....ill just make the bed up at the front ..Don’t you have the back seating area and side seats at the front?
Looking so much better already!So i managed to get all the plastics back on and painted today .....its better than the peeling paint .
Ive decided against sanding all the blue paint off as i really dont have the time to do all that at the minute so the bits that are peeled i will see if i can get a paint match i think or ill cover with a sticker or 2 ...
View attachment 541580View attachment 541581View attachment 541582View attachment 541583
DuhI know you will but just for my own peace of mind…. You are going to strap it down or/and put a lock on it…![]()
I think that having to make a bed up each night is gonna really get on your nerves seeing as you've been used to have one you can just flop into so going from the photos of the rear L lounge ...It has a small seating area at the back but when made to a bed you can't get in the toilet compartment. I also plan to put the pull out bit and extra cushions in the loft as i wont use them ....ill just make the bed up at the front ..
Its only 4.5 ft long so useless for me . I have to make a bed up every night in the caravan anyway so ill manage.I think that having to make a bed up each night is gonna really get on your nerves seeing as you've been used to have one you can just flop into so going from the photos of the rear L lounge ...
I'd be tempted to remove all the rear cushions and put in a 3ft single bed mattress as this would give you a ready made bed which would still allow access to the loo; if you left the small seat part and put a tray on top you'd have a bed-side table, alternatively take out the small cushion and put a crate or even a suitcase there to store other bits and pieces in still leaving you with the top of it as a 'table' area ... you can never have enough storage! You could also remove the washroom door completely and put a curtain up in it's place, or use the existing shower curtain to cover the gap so it looks 'respectable' during the daytime, you won't need to worry about having enough space to open the door fully then.
Ive not seen it but im sure its a family in a beige coloured bus ....they are up here touring Scotland at the minuteCheckout the Vario on millionaire motorhomes tonight. I'm sure you have seen them on the web.
Cheers James
From the difficulty you've had with the window panels I thought you were a short pip-squeak!Its only 4.5 ft long so useless for me . I have to make a bed up every night in the caravan anyway so ill manage.
Im 6ft 3 ....the vario is 3 metres highFrom the difficulty you've had with the window panels I thought you were a short pip-squeak!![]()
Yeap that's the one, shame they didn't do a decent van tour. Chopped about here there and everywhere!Ive not seen it but im sure its a family in a beige coloured bus ....they are up here touring Scotland at the minute
On Instagram @slowlywild
I dont think they've finished it yet...its still work in progressYeap that's the one, shame they didn't do a decent van tour. Chopped about here there and everywhere!
Cheers James
Have you shrunk?Im 6ft 3 ....the vario is 3 metres high![]()
I was 6ft4 in my 20's but only 6ft3 nowHave you shrunk?I’m sure I recall you once said you are 6ft 5…..but I guess you should know!
They do say size doesn’t matter,but I’m not so sure.![]()
Cannot believe you got that van for £3.5k!Weather has been shitty here today ...raining most of it so ive been cleaning inside the iveco ....looks a bit better now View attachment 541762View attachment 541763
It has let water in in the past around both the very rear window and the rear n/s side window as the walls below them are a bit spongy ...it might still be letting in so ill have to put a bit sealer around those ....the fancy side door is letting in water now and the trim around the top inside is rotten and wet ...so that needs sourced and dealt with also ...im hoping its just also needing sealed along the top .
These are the items i found during clean out ....View attachment 541766
Thats an unopened packet of cigarettes ...yet the guy was smoking prison style rollups ...
Couldn't believe the amount of sawdust under the seating etc you'd think it had never been hoovered since it was built
Figured out how to make a reasonably comfortable bed ...
Its a little short for me but if i sleep diagonally its ok .
The red scatter cushions and one ( seems to be extra back cushion ) are being put up the loft .
Im unsure at present whether this fridge is working or not ...so that needs investigation too.....that could be a right pain if it isnt.
If not a mattress, a mattress topper, more manageable size wise and should make a difference to comfort.I'd be putting a mattress in where the bed is made up, not ideal having to crawl over it or get in/out through the hab door but a better nights sleep.
Even better it was only £3kCannot believe you got that van for £3.5k!
Ps I'd remove the pic of the funeral service with personal details on it.....?
Cheers James
Ach ill manage ....ive slept on a lot worseI'd be putting a mattress in where the bed is made up, not ideal having to crawl over it or get in/out through the hab door but a better nights sleep.
