Yea but they only need a clean not demolishing.Drive into a tree branch - it never fails.
They are normally one of two types: LED - in which case they are one piece and are removed as a unit; or conventional bulb in which case they will be corroded, dirty, and with brittle plastic. The covers on these, if there are no visible screws, are removed by gently prising the lens away from the base. At which point you'll be able to see just why most of us leave well alone, wait for the inevitable tree branch, then replace them with one piece LED units.Yea but they only need a clean not demolishing.
If it's the white \ red high level lamps at the four corners of the motorhome I just replaced one of the bulbs in one of them. Ours is a 2013 Savannah and would guess your Mohawk would be same.Anyone know how to remove the top front and rear marker light lenses on a 2013 Mohawk?
There are two screws through the "glass" from the front that screw into the rear. Undo these and wiggle the "glass" about a bit as the rubber seal behind sticks a little bit.
Ours has 5W festoon bulbs.
ps replacement from here http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=192318231349
not brilliant quality (one faulty and one with "oversized" solder contacts) but we'll see how they go.
Hold that last result!Yes the red and white jobbies, mine don't have screws, so I don't know if the lens unscrews or is pried off. I will have another look tomorrow wiv me glasses on just to make sure there are no screws.
Would be interested to know the outcome assuming it doesn't entail the use of a hammer!Ok Gelly you can come of the naughty step now
The front white one looks the same, the red is probably the same will check tomorrow. Thanks for the photo's.
Didn't get round to trying to remove the marker lights, still on me to do list, now where's that bottle openerWould be interested to know the outcome assuming it doesn't entail the use of a hammer!
C'mon Dane, get a move on, we're all waiting to see if you bu@@er yours before doing ours.Didn't get round to trying to remove the marker lights, still on me to do list, now where's that bottle opener
I'm hanging the bag out Brian hoping someone else tries before I break mine tryingC'mon Dane, get a move on, we're all waiting to see if you bu@@er yours before doing ours.
Spoilsport.I'm hanging the bag out Brian hoping someone else tries before I break mine trying
Any chance it will move to the top of the list sometime this year?Didn't get round to trying to remove the marker lights, still on me to do list, now where's that bottle opener
I have just changed the bulb in mine (festoon) you can get a small flat screwdriver in slot and gently prise away from backplate.I'm hanging the bag out Brian hoping someone else tries before I break mine trying
Not that simple on my van the wiring is all behind the front pod with no access. I need to find where the wiring ends up.I replaced all mine with leds. The rear ones just prised off. The front ones entailed removing the speakers over the cab and accessing from the rear.
Dane, I think the other end of the marker light cables go to the FIAT Y203 connector which is in behind the "B" pillar panel just above the EM40 fuse board.Well that went well, NOT. Had another go at the top marker lights manage to get the light off and they are LED sealed units, it's taken me 4 years I only wanted to get the lens off to clean them but they have both now stopped working. I managed to get the correct ones HERE I got one off put the new one on but it still does not work and checking the old one it was ok. I couldn't test in situe as I they cable wouldn't come all the way out with the connecter so I had to cut it and remake the ends anyway.
So back to the drawing board, the rear and side markes all work ok and I would have thought the front top ones would be on the same circuit. Too wet today to see where the side markers terminate . The fuse for all the marker lights is on the EM module behind the drivers seat so would have thought it all went back to there but it didn't look like when I took it out.
Ah, will have a look there next.Dane, I think the other end of the marker light cables go to the FIAT Y203 connector which is in behind the "B" pillar panel just above the EM40 fuse board.
It's for a 2011 AT but probably the same for your 2013?Ah, will have a look there next.
Cheers Grant
