Yea but they only need a clean not demolishing.Drive into a tree branch - it never fails.
They are normally one of two types: LED - in which case they are one piece and are removed as a unit; or conventional bulb in which case they will be corroded, dirty, and with brittle plastic. The covers on these, if there are no visible screws, are removed by gently prising the lens away from the base. At which point you'll be able to see just why most of us leave well alone, wait for the inevitable tree branch, then replace them with one piece LED units.Yea but they only need a clean not demolishing.
If it's the white \ red high level lamps at the four corners of the motorhome I just replaced one of the bulbs in one of them. Ours is a 2013 Savannah and would guess your Mohawk would be same.Anyone know how to remove the top front and rear marker light lenses on a 2013 Mohawk?
There are two screws through the "glass" from the front that screw into the rear. Undo these and wiggle the "glass" about a bit as the rubber seal behind sticks a little bit.
Ours has 5W festoon bulbs.
ps replacement from here http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=192318231349
not brilliant quality (one faulty and one with "oversized" solder contacts) but we'll see how they go.
Hold that last result!Yes the red and white jobbies, mine don't have screws, so I don't know if the lens unscrews or is pried off. I will have another look tomorrow wiv me glasses on just to make sure there are no screws.
Would be interested to know the outcome assuming it doesn't entail the use of a hammer!Ok Gelly you can come of the naughty step now
The front white one looks the same, the red is probably the same will check tomorrow. Thanks for the photo's.
Didn't get round to trying to remove the marker lights, still on me to do list, now where's that bottle openerWould be interested to know the outcome assuming it doesn't entail the use of a hammer!
C'mon Dane, get a move on, we're all waiting to see if you bu@@er yours before doing ours.Didn't get round to trying to remove the marker lights, still on me to do list, now where's that bottle opener
I'm hanging the bag out Brian hoping someone else tries before I break mine tryingC'mon Dane, get a move on, we're all waiting to see if you bu@@er yours before doing ours.
Spoilsport.I'm hanging the bag out Brian hoping someone else tries before I break mine trying
Any chance it will move to the top of the list sometime this year?Didn't get round to trying to remove the marker lights, still on me to do list, now where's that bottle opener
I have just changed the bulb in mine (festoon) you can get a small flat screwdriver in slot and gently prise away from backplate.I'm hanging the bag out Brian hoping someone else tries before I break mine trying
