Marker lights (1 Viewer)
Oct 14, 2007
4,033
6,353
Rochester
Auto-Trail Mohawk
17 fun filled years
Anyone know how to remove the top front and rear marker light lenses on a 2013 Mohawk?
11,963
16,582
Yea but they only need a clean not demolishing.
They are normally one of two types: LED - in which case they are one piece and are removed as a unit; or conventional bulb in which case they will be corroded, dirty, and with brittle plastic. The covers on these, if there are no visible screws, are removed by gently prising the lens away from the base. At which point you'll be able to see just why most of us leave well alone, wait for the inevitable tree branch, then replace them with one piece LED units. :giggler:
Gellyneck
9,458
18,947
More than toes wet now!
If it's the white \ red high level lamps at the four corners of the motorhome I just replaced one of the bulbs in one of them. Ours is a 2013 Savannah and would guess your Mohawk would be same.
There are two screws through the "glass" from the front that screw into the rear. Undo these and wiggle the "glass" about a bit as the rubber seal behind sticks a little bit.
Ours has 5W festoon bulbs.
ps replacement from here http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=192318231349
not brilliant quality (one faulty and one with "oversized" solder contacts) but we'll see how they go.
Diabalo
Oct 14, 2007
4,033
6,353
Rochester
Auto-Trail Mohawk
17 fun filled years
Yes the red and white jobbies, mine don't have screws, so I don't know if the lens unscrews or is pried off. I will have another look tomorrow wiv me glasses on just to make sure there are no screws.
Gellyneck
9,458
18,947
Hold that last result!
It was a rear bulb I replaced and assumed all fitted the same.
However,
:doh: :doh: :doh: :doh: :doh:Sorry!
Diabalo
Oct 14, 2007
4,033
6,353
Rochester
Auto-Trail Mohawk
17 fun filled years
Ok Gelly you can come of the naughty step now:LOL:
The front white one looks the same, the red is probably the same will check tomorrow. Thanks for the photo's.
Gellyneck
9,458
18,947
Would be interested to know the outcome assuming it doesn't entail the use of a hammer! :whistle2:
Ivory55
6,017
14,537
North West Norfolk
Since Feb 2012
If you replace with led bulbs it comes up on the dashboard as a bulb gone, and I brought the ones that are meant to show resistance so this doesn’t happen. I just live with the warning light on the dashboard.
Diabalo
Oct 14, 2007
4,033
6,353
Rochester
Auto-Trail Mohawk
17 fun filled years
Didn't get round to trying to remove the marker lights, still on me to do list, now where's that bottle opener
Aug 19, 2007
717
1,081
Stockport
Tribute 615T sport
17 years + since 2006
I'm hanging the bag out Brian hoping someone else tries before I break mine trying
I have just changed the bulb in mine (festoon) you can get a small flat screwdriver in slot and gently prise away from backplate.
Diabalo
Oct 14, 2007
4,033
6,353
Rochester
Auto-Trail Mohawk
17 fun filled years
It's the front top ones I would like to get off to clean
Diabalo
Oct 14, 2007
4,033
6,353
Rochester
Auto-Trail Mohawk
17 fun filled years
Nearly 4 years ago I asked the question and still not removed the lens. I have prodded pried and try to unscrew all to no avail.
