Lenny HB
- Oct 18, 2007
- 58,128
- 179,481
- Carthago Compactline
Most people who fit Lithium do it for off grid use and rarely use mains for charging.Is the argument that factory fit alternator chargers provide ~20amps and as you aren't driving for 12 hours at a time, the voltage matters less and the BMS can work it out? So if you are happy with ~20amps, there's not much point in changing?
But mains chargers are more important because they do tend to get used for long periods, so the charge profile matters?
If you don't fit a B2B and have decent size wiring the Lithium could be trying to pull a 100 amps out of the alternator and could burn it out.
Not a good idea to reduce the cabling to limit the charging due to volt drop unless you like vehicle fires.
