Thanks, now just have to sort out spaghetti junction behind the EBL to fit the B2B. There are wires everywhere. But with cable ties, some laminate board and some brackets it should be fine
It all looks better with cable ties.Thanks, now just have to sort out spaghetti junction behind the EBL to fit the B2B. There are wires everywhere. But with cable ties, some laminate board and some brackets it should be fine
Check it without the engine running, positive on the multimeter to the D+ and negative to an earth point. Should be zero. Then repeat with engine running and should be 14V or so.It may seem a bit dim but what setting on multimeter and between D+ and what? With engine running?
I simply pull the 'kettle plug' out of the EBL.Hi . f #242. Can you just remove the 20 A fuse labelled Internes Lademodul to disable the EBL30 leisure battery charging?
To return to the question of Isolating the EBL 30 mains charging when on hook up.
Rather than removing the fuse is it not possible to remove the fuse & replace with a RKURCK re-settable 12 V DC 20 amp circuit breaker.
Simply plug the wires using 6 mm spade connectors into the fuse holder. Great car will be required that the 2 wires are not shorted, but make a good connection.
This will isolate the Hab charging, whilst maintaining all the other EBL functions.
It plugs in with a Wago connector just behind the EBL.Unfortunately the EBL30 does not have that type of lead it is hard wired. Also if you disconnect the mains, you loose the display panel over the door.
I have lost track of this thread a bit but why not just remove the 20A fuse. This will stop the EBL from charging your battery but leave the mains light on when on EHU and allow the trickle charge to the engine battery.Hi . f #242. Can you just remove the 20 A fuse labelled Internes Lademodul to disable the EBL30 leisure battery charging?
I finally got round to changing to lithium over the weekend.
I was instructed by SHMBO that I was not to do the job myself, as she could not stand the stress of me doing it & getting it wrong or struggling to do it. I would have had to do it parked up outside the house.
I had the job done by Oaktree Motorhomes , Rob & his crew were very professional & helpful. They answered my many technical questions. The job is great & seems to be working fine. I will have to learn what the system / App will do & how long I can stay off grid etc.
In the end I replaced the 2 X 95 Ah AGM batteries with one 110 Ah Eco Tree LifePo4 battery. I went down the Victron route & fitted a smart shunt, Orion 30 amp B to B & a new MPPT solar controller. There is still room for a second battery if needed in the future.
That's neat in comparison with what I could do! When i think of the first and second conversion i did!!,
Thank you Lenny HB , I had a feeling that you'd be along too! You read my mind re the 50A dcdc. Planning on fitting a Renogy DCC50 with solar capability.I can answer those for you.
Yes, the 20 fuse on the EBL just disconnects the mains charger to the hab battery.
Yes removing the 50 amp fuse by the starter battery disables the split charge relay and stops the hab battery charging with the engine runnng.
The 20 amp fuse by the starter battery supplies the fridge power with the engine running and trickle charges the starter battery from the EBL.
The cable from the 50 amp fuse is 16 mm sq, and would be OK for a 50 amp B2B if the cable run is up to 2m.
I would also add don't use that maxi blade fuse holder fit a Midi fuse.
Problem with that one is when it sees a solar input the B2B output reduces to 25amp. You can get arund with a switch on the solar input or a relay switched by the D+.Thank you Lenny HB , I had a feeling that you'd be along too! You read my mind re the 50A dcdc. Planning on fitting a Renogy DCC50 with solar capability.
That's a great idea re D+. So NC relay to allow solar. Gor it. I was planning on having a switch to disconnect solar, but like this way better! D+ from the front of the EBLProblem with that one is when it sees a solar input the B2B output reduces to 25amp. You can get arund with a switch on the solar input or a relay switched by the D+.
EBL is earthed via a cable at the back. Think it’s 16mm sq but might be bigger.Where is the EBL earthed?
Googlebot , thank you.EBL is earthed via a cable at the back. Think it’s 16mm sq but might be bigger.
Just waiting for a second B2B to arrive so can check if it’s vital? There may be other earth points as well.
I don’t think you need a hab battery feed into the back as that’s for charging. If you are using a B2B and bypassing the EBL, the connectors at the back are redundant.Googlebot , thank you.
I don't remember 2 wires going into the middle connector at the rear of the EBL (one from the hab battery and the other from the startery (earth). Unless theres a junction box bringing them together somewhere? I'll take a look in the morning.
I was thinking about using the existing wiring for the +ve and -ve on the B2BS , and running smaller wires from the hab battery to feed the EBL. What are your thoughts?
I think you will still need a hab/leisure battery connection to the EBL, the EBL still needs a 12V supply to power the habitation distribution. The 50A connection to the engine battery is more likely to be the redundant one if the B2B is connected directly to both batteries.I don’t think you need a hab battery feed into the back as that’s for charging. If you are using a B2B and bypassing the EBL, the connectors at the back are redundant.
autorouter or Lenny HB can confirm?
Pausim Thanks for this. I've found the EBL29 block/wiring diagram, and after trying to fathom it out, it seems that the EBL negative must go to the Hab battery (and shunt to measure if wanted), the EBL positive must go the hab battery (for display panel/level sensors/BL7 (external charger if needed)/solar).I think you will still need a hab/leisure battery connection to the EBL, the EBL still needs a 12V supply to power the habitation distribution. The 50A connection to the engine battery is more likely to be the redundant one if the B2B is connected directly to both batteries.
