Lenny HB
- Oct 18, 2007
- 58,093
- 179,310
- Carthago Compactline
When you have b***ed the new Lithiums?Done deal. See you Late Jan / Early Feb
?When you have b***ed the new Lithiums?
Been minus numbers in most of Scotland for the last week or so. Lowest so far -10C.how often in the UK .......... do we get minus
Scottish people won't buy Lithium batteries! They'd rather throw another Haggis on the Hob for heat and lightBeen minus numbers in most of Scotland for the last week or so. Lowest so far -10C.
Think -27.2C is still the lowest recorded temperature (Braemar and Altnaharra). -24.?C for Glasgow.
1963 average winter temperature for Scotland was 0C.
Don't be silly. Heat and light comes from candles.Scottish people won't buy Lithium batteries! They'd rather throw another Haggis on the Hob for heat and light
I stand correctedDon't be silly. Heat and light comes from candles.
Haggis in a hamster cage with an exercise wheel is for pumping the water.
With the video Charles is comparing a Lithium to flooded batteries & AGM, he has not compared it to a proper leisure battery i.e. a Gel. Gels are not much more expensive than flooded these days and are known to last up to 10 years, this would be a much fairer comparison but you won't get it from Charles he has a big dislike of Gels.
obviously Lithium are far better technically and a Gel has the disadvantage of long charge times and they don't like high current loads but on a cost comparison which is what this video is about I would have thought a Gel would come out tops.
if used in the same way
They can't be used in the same way as I use my Lithium. In summer I can hammer the batteries, leccy kettle, toaster, loading all the machine batteries, laptops, tablets ect Till the lithiums are really low by 3;30pm. Then know by 7pm and sun alone they will be chock full ready to go again. Gels will do the first part but they are just too slow to get back up in a short time
You don't seem to be taking it on board...But these have been used in the same way, off EHU and used for all sorts. Yes your correct they won't have charged back up as quick but the main point is they have provided all power and are in their 15th year.
Lithiums do sound great though I am just trying to understand what benefit they would give apart from weight saving
Trojan battery info
Trojan Lithium (Trillium) life cycle chart
Trojan Deep cycle Gel life cycle chart.
How come my 3 year old lithium phone battery is knackered then? I never let it go lower than about 30%You don't seem to be taking it on board...
Trojan battery info
If you absolutely abused the Lithiums they would last 10.95 years ( cycled every day to 100% discharge)
If you totally molly coddled the Gels they would last 7.53 years (cycled every day to only 20% discharge
Different battery chemistryHow come my 3 year old lithium phone battery is knackered then? I never let it go lower than about 30%
Also my ipod touch 5 hardly lasts an hour off it's charger nowadays ?
Oh the ipod got hot in the van once, I tried to use it and it said it needed to cool off a bit ? not aware the phone ever got hot.Different battery chemistry
High heat environment
B2B chargeri know the price of wet and lithium batteries but what else is needed for a lithium install?
Probably lithium cobalt, certainly not the LiFePO4 used for motorhome leisure batteries. There is no comparison.How come my 3 year old lithium phone battery is knackered then? I never let it go lower than about 30%
B2B charger
You shouldn’t connect lithium batteries directly to an alternator apparently, so a B2B charger would be required for charging on the move.I know Jim posted earlier that mos Lithiums advise installing a B2B.
I find that hard to understand considering the better performance of those batteries. Maybe somebody can explain the logic.
As I have posted elsewhere I would certainly encourage B2B use for lead/acid, but only if one moves regularly - they are not much use for 2 weeks on a site if no EHU, unless you want to annoy the neighbours by runnng your engine.
Geoff
Their won't be any problems providing you set to the correct charge profile. I think you will find the initial chare rate will be about 40-50amps unless they are completely flat, and soon drops to 20-25 amps and that is shared between your two batteries.I have 2 gel batteries and have just had a 60a B2B fitted. Reading comments here about gels not liking a high charge rate, have I wasted my money ?
They'll be smart alternators though, hence the need for the B2BI thought most Motorhomes had an uprated 160 or 180 amp alternator so with loads of spare capacity I wouldn't think it would be a problem.
That in itself is a little misnomer, it's the same alternator, just wired differently. You can DIY it if you know what you are doing. Change it from star to delta config and change the pulley and you'll have double the output.I thought most Motorhomes had an uprated 160 or 180 amp alternator so with loads of spare capacity I wouldn't think it would be a problem.
