MichaelT
Just for clarity the B2B charger goes between the normal engine battery and the Lithium(s) and the normal charging from the alternator is somehow disconnected?
If you buy a B2B with a profile to match your Li battery you may not need to worry about the mains charger. I haven’t. You will always arrive on site with a full battery and if you are on a hook up it only needs to supply a maintenance voltage. Unlike lead acid, Li batteries come to no harm from a little under charging. I know nothing of Nordelettronica chargers but if it has an AGM or Gel setting it should be ok.This thread has been a real education. But it raises a host of questions for me about what we need to fit in our van to change to Lithium. Perhaps some on here with technical knowledge/ experience would be able to make suggestions or advise the best way forward. I'm thinking the first thing we need is a B2B to get more charge into the batteries when driving, Lithium batteries to increase the useable capacity and a new mains charger to cope with the demand of the Lithiums when on hook up.
We have a 2017 Adria Matrix (semi integrated) on Fiat Ducato chassis with Euro 6 150bhp, 2.3 litre engine. The van is fitted with 2 x 80Ah AGM habitation batteries (now 2 years old) and the standard factory fitted (engine) charging system. A Nordelettronica NE237 sits in the battery box for mains charging. According to the handbook, this only puts 18A out, without a Lithium profile. We have 2 solar panels fitted, with a Votronic MPPT 350w charge controller. We have been electrically self sufficient whilst living off grid to date. We also have a 1200w Votronic inverter. It is only now, we have had a few overcast days and the AGMs have run down to 75% a couple of times.
Votronic market the VBCS 12V triple charger that includes B2B, mains charger and a solar controller, one device in place of three. One with a 30A B2B but the mid range one with 45A B2B would appear to maximise the B2B output under 50A for Lithium.
Questions I have are;
Q1: Are Lithiums the standard battery dimensions? Will I be able to fit 2 x 100 Ah Lithiums in the space?
Q2: How much power can we take from the alternator for the B2B? Will the van alternator power the 45A B2B? Or would the 30A be sufficient? The van is Euro 6, but earlier I read Fiat does not fit smart alternators to Moho chassis. Is this an issue?
Q3: What brand of Lithium? Earlier someone suggests the BMS are not all the same quality and there is a lack of common build standards. There also would appear to be a wide range of prices at the moment from Battery Mega Store to Relion to Sterling. Is it buy cheap, buy twice? What is it about the expensive ones that makes them any better?
Sorry for the long question, trying to sort this out in my mind as much as on the van!
That’s a good point; in theory the batteries should be/would be charged on arrival, unless a really short drive. But what about when/if they’re still only half charged and the Nordelettronica is powered up on mains? I don’t understand the science enough - will the charger that has a max output of 18A only pump out 18 A until it senses the batteries are full then change to maintenance charge, or will it overheat and think it’s been short circuited if the batteries are asking for more? Also, I would be worried that the Nordelettronica unit will overheat anyway after prolonged duration charging at full chat, because it will be putting more in than it would be with AGMs.
For Your Information. Enjoy.
Equally the author was known for spouting off about things then admitting he knew nothing about the subject matter when Jim called him on it, Also was known to post as a woman to start arguments and when called out and proven wrong would dismiss it as a simple mistakemy 2 x 110ah lead acids packed up in Spain recently so i replaced with a LiFePO4 100ah with Bluetooth realtime SOC, Volts and Amps. Also with beefed up cabling alternator to split on Euro 4. Very happy with enhanced charging.
This article was very useful against large scale propaganda and misinformation. (and vested interest and prejudice)
B2B, Battery to Battery chargers : Fast, Safe Motorhome Alternator charging
Euro 6 compliant Battery to Battery chargers for modern Motorhomes. Faster Habitation Battery charging that works in harmony with the existing wiring. Does not degrade the battery. Finally a solution to that can make a Hymer fully optimised for AGM batteries.www.aandncaravanservices.co.uk
R
Whilst I don’t doubt that putting in some decent sized cables would improve charging in some motorhomes I don’t think it resolves all the issues.my 2 x 110ah lead acids packed up in Spain recently so i replaced with a LiFePO4 100ah with Bluetooth realtime SOC, Volts and Amps. Also with beefed up cabling alternator to split on Euro 4. Very happy with enhanced charging.
R
The phrase "snake oil" springs to mind when I read that. As has already been said, but is worth repeating, if the cab and vehicle batteries are exposed to the same voltage the only way to quickly charge depleted leisure batteries is to expose the vehicle battery, which is likely to be more or less fully charged, to an excessive voltage, risking frying it. This is what a B2B avoids.This article was very useful against large scale propaganda and misinformation. (and vested interest and prejudice)
This guy, although no doubt well-intentioned, seems to have strong views without much solid facts to back it up. He makes the point that the alternator to starter battery wire is often inadequately thick, and even a very small voltage drop along it will affect the charging effectiveness. Beefed-up cables and a heavy-duty relay will often make a huge difference, so sometimes a B2B is not needed at all.B2B, Battery to Battery chargers : Fast, Safe Motorhome Alternator charging
Alan died a few months ago so not sure if his partner who has carried on the business will update the technical side of the website.However it seems to me that the Schaudt B2B is practically identical in function to a Victron or Sterling B2B, yet he puts the Schaudt forward as the solution to all the problems and disparages all the others.
Having said the above, I’ve just seen thisThat article makes interesting reading and andncaravanservices seem to know there stuff on lead acid batteries. But they’re certainly not singing along from the same hymn sheet as the motorhome fun crew on this topic.
This is a matter of science, not emotion, where I’m looking for facts and data on which to base a decision. Science debunked the witch doctors. There is nothing wrong with a challenge when data can speak for itself. Just it seems there is not much data out there on the effects of deep discharge on Lithiums. Where is the data challenging the aandncaravan DOD graphs?
I get the benefit of B2B; we set off this morning with the AGMs down to 65% and it’s taken 5 hours driving to get them back up to 100%, whatever factory kit the Adria is fitted with, putting a maximum 15 amps into them (according to the battery computer).
We need to know what effect on the life of a Lithium deep discharging has? Apart from the weight saving, isn’t the strength of Lithium based on the premise that it can be taken down to 80% DOD regularly? But now we see charts suggesting their lives are shortened significantly if they are worked like this, from 3 x 10 to the power 4 down to 0.5 x 10 to the power 4 number of cycles. I was expecting to see a doubling in my battery capacity, rapid recharging plus a payload reduction and long life. Utopia! But it looks like I’ll be spending up to £2000 to save 30kg without any real increase in useable storage capacity.
Where is the data?
Mercs yes but Fiat's pre Euro 6d were not fitted with smart alternators for the Motorhome converter market. I'm not sure about the Fiat Euro 6D.It is my understanding that using a B2B is a must with Euro 6 engines.
If you directly connect a fully charged battery to a nearly flat battery that is twice as big, then the first battery sends a big charge boost to the second battery, and they very quickly settle down to the same charge level, maybe about 50% or less. The alternator then has to charge starter and hab batteries back up to the 100% level. They'll be charged as if they were one large lead-acid battery. Which may or may not be what you want. As you say, a B2B avoids all that.if the cab and vehicle batteries are exposed to the same voltage the only way to quickly charge depleted leisure batteries is to expose the vehicle battery, which is likely to be more or less fully charged, to an excessive voltage, risking frying it.
That sounds simple but it's not what I've experienced. Before I fitted the B2B if we had the leisure batteries discharged down to say 60% the alternator would put a heavy charge in, say 20 amps or more for a while with the voltage at 14.4 but after half an hour or so the voltage would reduce significantly and it could take another four hours of driving to fully recharge them with a charging current of only around 5 amps. I don't think the split charge circuit was to blame as it had heavy cables and a 100 amp fuse. The B2B holds the voltage at 14.4 for an extended period, pushing in the amps.If you directly connect a fully charged battery to a nearly flat battery that is twice as big, then the first battery sends a big charge boost to the second battery, and they very quickly settle down to the same charge level, maybe about 50% or less. The alternator then has to charge starter and hab batteries back up to the 100% level. They'll be charged as if they were one large lead-acid battery. Which may or may not be what you want. As you say, a B2B avoids all that.
Bless him, he's no longer with us. Often held up as an authority on many topics. He really knew his way around Schaudt Elektroblocs, and repaired hundreds.
He fixed an Electroblock for me, staying late after hours to get it sorted for my trip the next day. Yes, a nice guy.He was a nice guy who often meant well. He had a couple of kids and died far too young.
