BatteryMegaUK do these batteries have a system to prevent charging below 0°C ?
Did you mean 100 amps max discharge and 50 amps max charge because what you wrote there doesn't make sense I'm afraid.Hi Andy,
The max charging current is 50AH the max discharge current is 100AH.
I think you will find that a LiFePO4 battery is far less troubled by discharge rates. Lead acid batteries waste more power the higher the rate of discharge. This is calculated using a formula known as Peukert’s Exponent, if I have understood the law correctly this means that in effect a 100Ah battery drops to perhaps 90Ah or 80Ah if you whack it particularly hard. The effect of heavy discharge on a Lithium battery is much less and can be mostly ignored. The recharge rate is also better on the Lithium, probably 99% whereas a Lead one is usually 95%. Not of much significance when on hook up or engine charging but may be relevant if you are struggling to keep up on solar power in a UK winter.Did you mean 100 amps max discharge and 50 amps max charge because what you wrote there doesn't make sense I'm afraid.
Usually there is also a continuous discharge and max discharge rating. (One that it can maintain safely until flat and a higher discharge current that is time limited.
Do you know these figures?
The BMS will have a continious discharge and a max discharge current though ?I think you will find that a LiFePO4 battery is far less troubled by discharge rates. Lead acid batteries waste more power the higher the rate of discharge. This is calculated using a formula known as Peukert’s Exponent, if I have understood the law correctly this means that in effect a 100Ah battery drops to perhaps 90Ah or 80Ah if you whack it particularly hard. The effect of heavy discharge on a Lithium battery is much less and can be mostly ignored. The recharge rate is also better on the Lithium, probably 99% whereas a Lead one is usually 95%. Not of much significance when on hook up or engine charging but may be relevant if you are struggling to keep up on solar power in a UK winter.
Now I'm home I have a bit more time to explain rather than trying to post with one hand, ram some food down my neck with the other and have one eye on the clockI think you will find that a LiFePO4 battery is far less troubled by discharge rates. Lead acid batteries waste more power the higher the rate of discharge. This is calculated using a formula known as Peukert’s Exponent, if I have understood the law correctly this means that in effect a 100Ah battery drops to perhaps 90Ah or 80Ah if you whack it particularly hard. The effect of heavy discharge on a Lithium battery is much less and can be mostly ignored. The recharge rate is also better on the Lithium, probably 99% whereas a Lead one is usually 95%. Not of much significance when on hook up or engine charging but may be relevant if you are struggling to keep up on solar power in a UK winter.
OK but please try not to lose any bets when you have wagered sensitive parts of my anatomy.I bet your left bollock these don't do that though...![]()
Some Lifep04 cells (individual 3.2v cells!!!!!!!!!) like the red headways can do 160amps max discharge 80 amps continuous at 3.2v.
OK that makes sense.
That's bonkers when you consider making a 12.8v battery it can produce 320 amps on its own SAFELY!
I can't work that one out. 4 x 3.2 is indeed 12.8. But 4 cells can only produce 80A.
Some Lifep04 cells (individual 3.2v cells!!!!!!!!!) like the red headways can do 160amps max discharge 80 amps continuous at 3.2v. That's bonkers when you consider making a 12.8v battery it can produce 320 amps on its own SAFELY!
all right keep your allens onErm, NO! If a single cell can produce 80 amps continuous, then any number of cells in series will never produce more. Thus 4 3.2v cells in series will still produce 80amps, not the 320amps you claim.
Its not all that amazing, I have some standard 3Ah lithium batteries which will produce 150-160 amps continuous, though not for all that long.
If my maths is right, with an internal resistance quoted as up to 45 milli ohms, (which is quite high) at 100 amps the voltage drop will be up to 4.5 volts.That's more like it. Thank you ??.
So at 12v (don't know yet what the voltage sag is going to be like at 100amp draw) we can see it can do 100 amps continuous with a max of 200amps for 3 secs.
Not bad!
I think you might be confusing 95A with 95Ah. The first is a measure of the output at any particular moment, the second is the cumulative effect over the period of one hour. A 95A alternator can supply a flow of current of 95A.I think the standard alternator on my van is rated at 95 amps , does this mean it can produce 95 amps straight up or over an hour?
A little off course here I know.
The blurb for Lithium drop in batteries all say they can be charged using existing charging methods for lead acid/ agm,
What they don’t say is whether the charging system can handle the current that they want to suck from the system.
As I understand it to be safe you need some kind of current limiting gadget, why?
Now can someone tell me when I start my van from the 110Ah start battery it has to supply a very large amount of current to turn over the engine, depleting the battery.
Once the engine is running the alternator then surely is working its socks off to recharge the battery.
I’ve read somewhere that the resistance, temperature and state of charge of the battery limits the current.
Now my point is this, if the alternator can produce this kind of power why would I need to upgrade the cables etc. to charge a lithium battery that wants to take everything I could throw at it,
Or is it to maybe protect the lithium battery itself from too much charging current hence the need to limit the current?
One for the auto electricians.
They are offering advice and a wealth of knowledge to help Funsters.So what is the point of this thread![]()
Our Lithium can only be charged safely using either a mains charger or battery to battery charger with suitable voltage and amps settings within the range described on our specification sheet. I cannot be connected directly or indirectly to alternator output charging. I imagine it is the same for all lithiums.
Someone learning on the job?So, in light of this last post, what on earth is the point of the first post.
I recently purchased one of those small "Battery Banks" which allegedly will start a Big Diesel (not tried it, Yet).
It is one of the reasons I installed a B2B.What do you take from that?. At first glance, It would appear that fitting a Li-?? battery as "starter" would require extra protection?. Perhaps if using Li-?? batteries for Habitation, the "trick" would be to have them separate electrically and use (say) a B2B unit to charge them when on the move?.
Does that work?.
