BatteryMegaUK
Trader (Batteries)
- Jun 20, 2019
- 44
- 106
- Don't own one yet
- Battery Expert
Hi, can you tell us how you tested this? for instance how many charge discharge cycles over what period of time and the condition of each battery at the end of the test. I think people investing in expensive lithium batteries would want to know they are not shortening the life of the battery by using an incorrect charging regime.
Hi there
Thanks for your question!
We completed 16 cycles in total with the batteries wired correctly in parallel (not daisy chained, but cross wired which is crucial for lead or lithium). 8 cycles were recharged on a Victron charger “lithium setting” and 8 cycles were recharged on the “lead acid settings”? The purpose for this was to check lithium received a full charge and that the lead acid was not over charged. Both were as we'd expected and we shared our results with TN who confirmed and said actually at a lower charge voltage the lithium will actually last longer than spec.
The discharge was on our Astratec discharge tester which applies 20amp load continuously until the 190ah (rating for combined ah) was reach. Each test passed, which is great as Astratec finds any faults, they simply can’t hide from it.
You may all like to know we have a lot of TN power on test in the commercial market and they have all passed with flying colours, we have also submitted it for testing with the NHS. The range is expanding, it cost around $10k to UN38.3 each part number which is why we didn’t launch the whole range at once, but we will soon have 12ah,24ah,33ah, 54ah, 84ah,100ah, 110ah
