Of your present 110 LA battery you have about 55 amps usable power as LA's shouldn't be discharged more than 50% .Hi all
Looking at lithium battery
Got a 110ah lead battery now
If I upgrade is a lithium 230a twice the capacity of the 110ah and a 3000a 3xbetter or does it not work like that?
Fitted a 130w solar panel with mppt controller wich supports lithium so do you just drop battery in and change to lithium on controllerOf your present 110 LA battery you have about 55 amps usable power as LA's shouldn't be discharged more than 50% .
A lithium can be discharged much lower so a 230 amp lithium will have nearly 4 times the usable capacity.
It can also be discharged and charged at much higher rates than LA.
Obviously you need to make sure that your charging sources have a lithium charge profile as their charging needs are different to LA.
Mmm it is irlandI would say it depends on how often you drive, whether you have B2B and how much power you use then of course, will the sun shine?
Not just for 3 weeks we do a lot of weekends awayReally depends how much money you want to spend. A 230 lithium will be quite pricey for a 3 week trip.
Every couple of daysHow often will you be moving?
Yes as far as charging from solar you change the MPPT setting to lithium.Fitted a 130w solar panel with mppt controller wich supports lithium so do you just drop battery in and change to lithium on controller
I have 130w solar with matt controller lithium compatibleSo you need a couple of days battery power assuming no solar input then anything you do get will be a bonus then your next issue is how you are getting that charge back in before your next stop.
I wouldn't say you need lithium but there's no doubt it's a better battery if you don't mind paying a bit extra for it.
Will be going on the odd site for a bit of luxuryWhich is no good if the sun doesn't shine so if you do your calculations on that assumption you will not be caught short as I said anything you do get is a bonus.
So you will get a full charge there, you need to work out how much power you use each day so that tells you how long you can stop in one place, then you need to know how long you need to drive to put that power back into your batteries, for example I know that I can use all my 240v toys for 6 days before the batteries need a charge (longer if the sun shines but as I say that is a bonus) then I know that I can charge while driving at a rate of around 90 amps per hour so I need around 6 hours to get a full charge before I can do another 6 days, as I say though the sun is the unknown variable and as the summer approaches it plays a bigger part in you power balance, again for example I know that on a good sunny day we can get 200ah from the solar so a couple of days free power and even an overcast day we are not far off breakeven.Will be going on the odd site for a bit of luxury
This time of year 130 watts of solar won't provide much so your main way of recharging a battery will be from your mains charger when on EHU on site and your alternator when you drive every couple of days so those 2 charging systems will need to be looked at to see if they are compatible with lithium.Will be going on the odd site for a bit of luxury
What you got on yours to last 6 days?So you will get a full charge there, you need to work out how much power you use each day so that tells you how long you can stop in one place, then you need to know how long you need to drive to put that power back into your batteries, for example I know that I can use all my 240v toys for 6 days before the batteries need a charge (longer if the sun shines but as I say that is a bonus) then I know that I can charge while driving at a rate of around 90 amps per hour so I need around 6 hours to get a full charge before I can do another 6 days, as I say though the sun is the unknown variable and as the summer approaches it plays a bigger part in you power balance, again for example I know that on a good sunny day we can get 200ah from the solar so a couple of days free power and even an overcast day we are not far off breakeven.
How is it bigger i don't know what he has.Yes, but everything he has is bigger than yours!
Ian
640ah Lithium, 90 amp B2B and 520 watts solar, that's 6 days using electric kettle microwave coffee machine etc etc, my point was though that you need to understand what you use and what you have stored and then how you replace it, you don't need what we have for 6 days, you just need to use power according to your capacity, before we doubled the lithium capacity we would use a gas kettle and still OK for 6 days in the winter.What you got on yours to last 6 days?
Ian does though it's not what you've got it's what you do with it.How is it bigger i don't know what he has.
I don't use much in van only 12v off ehu no mwave, hdrier, only 12v tv shower phone charging lights
As a further example I had 220 ah of gel and 120 watts of solar and never ran out in France in the summer, until I got Ebikes.640ah Lithium, 90 amp B2B and 520 watts solar, that's 6 days using electric kettle microwave coffee machine etc etc, my point was though that you need to understand what you use and what you have stored and then how you replace it, you don't need what we have for 6 days, you just need to use power according to your capacity, before we doubled the lithium capacity we would use a gas kettle and still OK for 6 days in the winter.
Sounds like 2 lead acid leisure batteries would do you rather than going to the cost of lithium.How is it bigger i don't know what he has.
Iv'e never seen 6 inches go so farIan does though it's not what you've got it's what you do with it.
Not sure if I can fit another battery in as compartment too smallSounds like 2 lead acid leisure batteries would do you rather than going to the cost of lithium.
If that's all the power you are using then depending on how long you have your TV on for, which will be your biggest drain, 2 x 100AH lead acids should give you about 4 days with no charging input.
