I don't think so with LA as the voltage across the terminals increases the the charge rate will drop due to increased internal resistance.
With Lithium the voltage stays pretty constant although they are normally charged at 14.2v if the voltage drops to 13.5 they will still suck in 100 amps if they can, so that bit of thin wire is going to get very hot.
I don't think that's quite fair. Cable size will be sized for maximum designed load, not the power source as that is just theoretical. I could have 100A alternator and my load might never exceed 10A for example, the alternator (or any power source for that matter) will never deliver 100A in that situation. Current is drawn from a power source, not delivered by the power source.They will only suck in 100A if the alternator is capable of delivering 100A. If the system has been designed, and installed, correctly the cable should have been designed to handle the maximum that the alternator can deliver (and the use of terms such as skinny, long thin wire is unhelpful). The lithium is just a load, the cable should be sized for the power source (alternator) delivery capability. This isn’t a lithium issue, this is a bad design issue where cables are inadequately sized and is simply bad practice.
Ian
You can do that with all B2B's but useless if you have solar charging the starter battery. It will create an endless loop, when the starter battery reaches the trigger voltage of the B2B it will turn on and start charging the leisure battery, flattening the starter battery, starter battery gets low the B2B will turn off and the cycle starts again.I will say that you could use the Renogy B2B unit which does not require the D+ signal as it works on the voltages. I actually ran the D+ on mine but did not connect it as it ran perfectly well without it.
Absoolutly correct, except that the Renogy I have is also a solar charger so sorts that out. The only downside is that it is a 50amp B2B and it will use both solar and the alternator and restricts the alternator to 25A if there is anything on the solar. This suits me for normal operation but if I need the full 50A from the alternator I just switch off the solar.You can do that with all B2B's but useless if you have solar charging the starter battery. It will create an endless loop, when the starter battery reaches the trigger voltage of the B2B it will turn on and start charging the leisure battery, flattening the starter battery, starter battery gets low the B2B will turn off and the cycle starts again.
Same thing happens when charging from mains but not quite so important.
You didn't say it was a dual one, you said Renogy B2B, they make both types.Absoolutly correct, except that the Renogy I have is also a solar charger
Me badYou didn't say it was a dual one, you said Renogy B2B, they make both types.
I think what you are really saying is that it would be better practice to assume over the life of a van that the load may change due to upgrades etc.
In which case the original design specification has changed. Therefore it may be a good practice to overspec the cabling beyond the original design and bringing that in to line with the alternator rating "could" be useful if the future change in load design can still be delievered without changing the alternator.
But what are you asking here?
Over-engineering is not good practice, good practice is engineering the entire system to the design requirement specification.
All nicely charging circa 110 amps all connected up with 50mm2 multi strand Copper wire
"Wot voltage drop?"
I would have thought voltage sensing was dead in the water with all new motorhomes having smart alternators. They need a B2B and voltage sensing will not work properly with smart alternators. If it doesn’t have D+ then I wouldn’t buy it.Just a comment ref B2Bs and votlage sensing ....
As has been said, lots of B2B units are activated via Voltage sensing, and that is becoming the norm for new units I would say.
Makes sense, I was also concerened about the solar, especially as once setting the solar regulator to lithium it will hit 14v+ which would surely trigger the B2B.I would have thought voltage sensing was dead in the water with all new motorhomes having smart alternators. They need a B2B and voltage sensing will not work properly with smart alternators. If it doesn’t have D+ then I wouldn’t buy it.
Dave, I'm with you re "my brain hurts".Does anyone remember the Monty Python sketches 'my brain hurts'??
I thought I had it all worked out re fitting a B2B (Sterling 30A, which I have ready to go, or buying a 60A Renogy)
I was also going to have the modification done by Apuljack on my NE237.
But now it seems as though there is an issue if I have solar connected to the vehicle battery (mine is directly connected rather than through the NE237) and then add a B2B ...
You don't need to go anywhere near the engine to get a D+ signal, converters fit a D+ relay box as there is no way the D+ output from the alternator could supply all the items requiring a D+ trigger on a modern van.But I imagine this is even harder to get the wire routed than D+ itself. (at least in an A-class with the letter box bonnet)
Yes, identifying it is another issue. I looked where vanbitz suggested but the wiring colours change somewhere. At the back the D+ is all green, in the relay box there is no green at all. All documentation only talks about fuses and doesn't help.You don't need to go anywhere near the engine to get a D+ signal, converters fit a D+ relay box as there is no way the D+ output from the alternator could supply all the items requiring a D+ trigger on a modern van.
Correct JockDave, I'm with you re "my brain hurts".
I believe that my solar setup is connected directly to the batteries via Votronic MPPT regulators, (2 x), but I chose the ignition sensing D+ for my Sterling 60A B2B. It's all working fine, without depletion of one battery bank by the other.
HTH,
Jock.![]()
But you had yours installed by someone who knew what they were doing, mine is being done by a right cowboyDave, I'm with you re "my brain hurts".
HTH,
Jock.![]()
IIRC, I think I extended it from the fridge/freezer connections, through into the garage to the B2B, as close to the battery banks as possible.Correct Jockyour D+ is a proper alternator derived signal not voltage sensing.
EDIT I will add unless somebody has fiddled since I fiddled![]()
The standard DS300 has a simulated D+ output protected by a 3A fuse. You should be able to pick this up fairly easily.Yes, identifying it is another issue. I looked where vanbitz suggested but the wiring colours change somewhere. At the back the D+ is all green, in the relay box there is no green at all. All documentation only talks about fuses and doesn't help.
From the DS300 yes easy. Getting that wire over to the lesiure battery in my van is just not worth the hastle. I tried to follow the +ve back from the lesiure battery, it went behind the water heater which requires the entire kitchen to be dismantled to get to, then vanished somewhere behind the bathroom wall which would require the entire bathroom sink/wall furniture to be dismantled. Honestly the easiest way would be just drilling throught the floor and going under the van. I honestly don't know what they were thinking when they fit the water heater, I hope I never have to take it out!The standard DS300 has a simulated D+ output protected by a 3A fuse. You should be able to pick this up fairly easily. View attachment 762779
A Rapido by any chance as they appear to be masters at fitting the heater in inaccessible places & needing to dismantle half the van to get it out.I honestly don't know what they were thinking when they fit the water heater, I hope I never have to take it out!
Yep, other than that it is fantastic van. We went through 4 other vans before this and it is by far the best.A Rapido by any chance as they appear to be masters at fitting the heater in inaccessible places & needing to dismantle half the van to get it out.
Not only that, but also the D+ is actually not necessary. The reason for using the D+ rather than the ignition key turnon signal is related to the split charge relay. The ignition signal turns on and switches the starter motor on. If it turns on the split charge relay, there is a direct metallic connection between the batteries. The leisure battery will attempt to supply a percentage of the starter motor current, which is very high amps, and is not good for leisure batteries or the wiring. The D+ doesn't turn on until the starter motor has finished and the engine is running.To state the obvious the D+ is nothing special, its just 12v that is only there when the engine is running. Obvious places would be in the control unit or the 12v supply to the fridge. If you really had to you could just have a switch and remember to turn it on and off.
That makes sense but I would have thought that having the B2B go live and put an additional drain on the engine battery at the very time the battery is needed for engine starting is not ideal.Not only that, but also the D+ is actually not necessary. The reason for using the D+ rather than the ignition key turnon signal is related to the split charge relay. The ignition signal turns on and switches the starter motor on. If it turns on the split charge relay, there is a direct metallic connection between the batteries. The leisure battery will attempt to supply a percentage of the starter motor current, which is very high amps, and is not good for leisure batteries or the wiring. The D+ doesn't turn on until the starter motor has finished and the engine is running.
However a B2B isn't a direct metal connection, there's a one-way diode for a start, so there's no reverse current flow towards the starter battery, and that problem goes away. If it's triggered from the ignition switch then, although it's not ideal, it won't cause huge problems.
I'm not great at this stuff but my understanding is the D+ comes off the alternator so will only click into action once the engine has actually fired. So the connection wont be there until the engine has taken the load off the starter motor anyway?Not only that, but also the D+ is actually not necessary. The reason for using the D+ rather than the ignition key turnon signal is related to the split charge relay. The ignition signal turns on and switches the starter motor on. If it turns on the split charge relay, there is a direct metallic connection between the batteries. The leisure battery will attempt to supply a percentage of the starter motor current, which is very high amps, and is not good for leisure batteries or the wiring. The D+ doesn't turn on until the starter motor has finished and the engine is running.
