I have had a word with Greta and she said it’s people like you coming home in the winter after working outside and having hot baths that are melting the ice cap . Haha. If you drive a diesel you have to have stone cold baths. HahaRight first hurdle to overcome!!
plumber has been, turned up valve under sink, not any noticeable difference! But he’s not legally allowed to do anything else!
removal of the valve/ thermostat would be the answer, so I’m going to speak to the housing and see if they would let me pay to have it taken out or bypassed! It’s all to do with a death of a child apparently, now all taps on bath are only set to around 46degrees,, no bloody good to me!
I don’t mind paying to remove, and I won’t mind paying to replace if I leave, but we shall see what they say! Stupid regulations, cold baths, and showers!!
will let you know how it goes! Xxxx.
on the other hand I could say nothing, get it taken out privately, and take a chance, but I shall speak to housing first! Xx
You have got to be very careful though when it's not your property. not very likely, I know but what if someone did come in and get burnt or something, you would be sent to hell.Personally I would just do it & keep mum!
Remember it tho and re-instate when/if you move on.
You can adjust them but only in the range 35C to 45C.Take the bath panel off then the valve cover and see if you can wind it up ?
Obviously I’m not telling you to do it and all risk is down to you ??
I think Ian's is not one of these, see below, which has two hot water feeds, one to the shower ( will be very hot and can be used to fill the bath with hot water) and another which feeds the bath tap is limited to 45C.no chas, it runs of the same plumbing! View attachment 356256
Tricky, because I'd assume they will say no, in order to cover themselves against any possible subsequent claims; and it may contravene current Building Regs also?on the other hand I could say nothing, get it taken out privately, and take a chance, but I shall speak to housing first! Xx
With a combination boiler, as others have said, you have to run the hot tap really slowly to get the water hot enough, as it’s heating it up as it goes through. In the winter we have to trickle it in to get it hot enough for Paul! Ok for the grandkids tho!
Ian and kettles have a bad historyAs a temporary fix you could boil the kettle a time or two and add that to the bath.
Yeah I know but it's what everyone had to do when I was a kid.Ian and kettles have a bad history
my gran had a big pan in the kitchen for boiling water to do the washing and to fill the bath tub. 2 large handles on it to lift and pourYeah I know but it's what everyone had to do when I was a kid.
If the shower temp is not restricted before the shower mixer, but the bath hot tap is, then why not unscrew the shower head, turn shower mixer to max hot, and let the shower hose fill the bath up?
Or is that too simple,......or am I for that matter?
LES
Doh! sorry mate, got your picture mixed up with the ex gasmans I think, ah well that idea is buggered.shower comes from taps,, see previous pic les,, xx
Come on olley, isnt a £1 a week & copious amounts of freshly brewed tea enough for you?It's better to beg forgiveness (if you get caught) than to ask permission.
HA will refuse you, they have to, pity I am not closer I would do it for you.
I had a combi boiler in my previous house and the shower was fab..Red hot fast flow and lots of pressure...BUSBY.With a combination boiler, as others have said, you have to run the hot tap really slowly to get the water hot enough, as it’s heating it up as it goes through. In the winter we have to trickle it in to get it hot enough for Paul! Ok for the grandkids tho!
At 45 there's a greater risk of hypothermia, at 65 it's uncomfortably warm but harmless, at 70 it's spot on for warming a cooling-down bath .You have got to be very careful though when it's not your property. not very likely, I know but what if someone did come in and get burnt or something, you would be sent to hell.
