Lenny HB
- Oct 18, 2007
- 59,496
- 186,711
- Carthago Compactline
On the last van I found set to 35 deg worked well fans came on when ambient was 25deg, so I will start there and see how in goes. I think I set the hysteresis to 2 deg the standard setting of 5 is a bit wide.What temperature do you set the controller to switch on the fans Lenny?
Yes, it was convenient as I had cat5 cables and a connector around & used bullet connectors for the main power in, only done so the grill was easy to remove, I used cat5 fly cables has they use flex where as cat5 structure cables are solid. Didn't bother with a separate fuse as I took the power from the oven light/ignitor input which is a 2A fused supply.Sorry @Lenny HB for all the questionsParts ordered, so again thank you for the links.
I see you've used cat5 which I presume is to feed power to the controller from the fused supply to the fridge and then back from the controller to power the fans as and when the relay clicks in, is this correct?
Regarding sensor location, where have you fixed yours?
If you look at the 1st photo the sensor is on top of the angle alloy between the fans, mounting it on the alloy gives a bit more stability to the switching as it will not be affected so much by air currents (well that's my theory).
That reminds me must tidy up that sensor wire it looks scraggy.
