Just too tight for screws. Tomorrow tells whether the seats still turn and if the clamps aren't glued on.1st one lasted 2 years last couple only about 3 months but it was Poundland epoxy.![]()
Glad I used steel then.I used the posh stuff Araldyte, when I first did this mod when van was 4 months old I used Aluminium. This later turned out not to be a smart move the spring loaded locking roller wore them quite badly, not a problem in itself but the resultant fine coating of very very conductive ally dust made a mess and there’s a lot of electrics/electronics under the rh seat. Now changed to steel
I managed to flatten a brand new battery when my motorhome was sitting on the drive not connected to 240v. I don't have solar.I fitted 3 double usb sockets, and 2 additional 12vdc sockets, bought a 6 way fusebox on fleabay and took feed directly from leisure batteries circular rocker switches fitted to usb sockets, 2amp fuses for usbs, 10 amp for sockets. Inline 20a fuse between fusebox and batteries, Like Lenny I have never switched panel off in almost 15 months of ownership.
300 watts of solar, all detailed in this thread, & all my USB sockets are switched. even without solar I would expect my batteries to be OK for 10 or 12 weeks (3 x 78ah Gels).I managed to flatten a brand new battery when my motorhome was sitting on the drive not connected to 240v. I don't have solar.
I was informed that even if switched off the control panel is active as is the Truma water dump valve. Dealer also fitted a USB directly across the leisure battery so never switched off. Battery discharged to 11.5v after a couple of weeks and now hardly maintains charge. How do you manage without switching the 12v off or are you on hook or solar? Many thanks
Many thanks once again Lenny. My battery is an exide gs900 85Ah connected though an EBL119 so don't understand why it fattened itself. Now keeping 12v off just in case.300 watts of solar, all detailed in this thread, & all my USB sockets are switched. even without solar I would expect my batteries to be OK for 10 or 12 weeks (3 x 78ah Gels).
My EBL119 comes fitted with a 12V cut off switch but as everything was switched off - or so I thought - I hadn't bothered to switch it off. Apparently the electronics can be 'active' even although nothing visible switched - particularly the Truma water dump valve. Brand new battery discharged to 11.5v so 50% discharged. Now using the cut off switch when not using the motorhome. Will have a look at the switch you mentioned. Thanks for the feed back.You could fit a battery isolator switch to cut off all your 12v systems.
Car Battery Switch Isolator Terminal Quick Cut-off Disconnect Master 12V 24V New | eBay
Simply loosen or remove the wheel to disconnect. Battery disconnect switch. Suitable for 6V, 12V and 24V batteries. Colour: Gold / Green. 1 Heavy Battery Switch. Classic Car Part: Yes.www.ebay.co.uk
Do not use the cut off switch on the EBL if it is more than a couple of years old they are notorious for failing, you swtich them off and they won't switch on again.My EBL119 comes fitted with a 12V cut off switch but as everything was switched off - or so I thought - I hadn't bothered to switch it off. Apparently the electronics can be 'active' even although nothing visible switched - particularly the Truma water dump valve. Brand new battery discharged to 11.5v so 50% discharged. Now using the cut off switch when not using the motorhome. Thanks for the feed back.
Just finished reading your complete post and my heads buzzing!If you read the thread from the start it covers nearly everything I've done to the van.
Thanks Lenny. Van is 4 years old and so far no problems but I take on board your info regarding the switch. Yeh reckoned my battery is goosed which p@ssed me off more than just a little as I only bought it a couple of months ago and the van has still to be used in anger.Do not use the cut off switch on the EBL if it is more than a couple of years old they are notorious for failing, you swtich them off and they won't switch on again.
11.5v is beyond flat if it's been left at that voltage for any length of time the battery will have had it.
The electric dump valve was replaced with a mechanical one over 12 years ago.particularly the Truma water dump valve.
Still charges the leisure batteries at up to 18 amps as the leisure battery take priority, it won't charge the startwet battery until the leisure battery is nearly charged.I note your point regarding the starter battery taking 2A and not the 8A as I had been informed. This leaves me with 16A available from the EBL119 to charge the leisure batteries. ie 2 x 80Ah gel batteries.
95% of our charging is from solar, our winter Motorhoming is in Spain or Portugal.You have 234Ah installed. How does your Elektroblock handle this or is it simply a matter that when driving it just takes longer to fully charge your batteries or can your Elektroblock handle more than 18A?
More efficient to connect directly to the batteries no advantage via the EBL unless you have a control panel that displays current if so you can get a loom to connect the Votronic.Does the Votronic connect to your electroblock as does the LRM1218 thus allowing the EBL to control all the charging requirements whether driving, on EHU or off grid.
What I really want to end up with if possible is probably 200W of solar, a solar controller and possibly a couple of 100Ah batteries all connected through the EBL 119.
Many thanks once again Lenny. I now feel much more comfortable with what I have and what I need to do to get to where I want to be.Still charges the leisure batteries at up to 18 amps as the leisure battery take priority, it won't charge the startwet battery until the leisure battery is nearly charged.
Just had a reply from Udo LangMany thanks once again Lenny. I now feel much more comfortable with what I have and what I need to do to get to where I want to be.
As solar for most part in Scotland is not great I'm thinking I would still require charging via the EBL. Great for when I'm in France.
So until I'm in a position to fit solar and most likely the Schaudt LRM1218 solar charger my best option would be to fit a couple of say 85Ah gels?
Got a new van on order, probably leave most of the suff in it as getting a very good price for it and want to fit better equipment to the next van.So, tell me Lenny HB is this van your "keep forever" please?
If not do you remove any of the mods when you sell - I've been told by several different dealers,
they are not interested in "extra's" when it comes to trading in your van!!
Fantastic article and very good reference to doing mods. Keep em coming please
Are you trading it in on the new one…? That’s a shame as I would of given you £20k… might of even stretched to £22k…..Got a new van on order, probably leave most of the suff in it as getting a very good price for it and want to fit better equipment to the next van.
Would have liked to transfer the air suspension but the Goldschmitt air is not approved on the new van.
Yep agreed a trade in price held until delivery in about a year. You need to quadruple your offer.Are you trading it in on the new one…? That’s a shame as I would of given you £20k… might of even stretched to £22k…..![]()
Yep agreed a trade in price held until delivery in about a year. You need to quadruple your offer.![]()
I know what your red wine stock is like.I’ll Chuck in a nice bottle of red….![]()
Yes I would have liked you to transfer the air suspension………Would have liked to transfer the air suspension
Hi Lenny......I am just in the process of following your lead with the internal fan, can i ask where you picked up the 12v feed from, for info i also have the RMD8505 in a Hymer and if you were to do the same project again would you consider fitting 2 internal fans?Finaly got around to fitting the internal fridge fan. Spent several days measuring temperatures first and quite an improvement with an internal fan. This was the hot week where outside temps were 27 - 30 deg.
Decided to use one of the mini PCB controllers so tha everything could be mounted inside the fridge with only a power feed required.
Original plan was to pick up power from the door switch but only 10v measured there so must be fed from the control electronics so that was non starter.
Took off the fins and it was easy to feed the cable through the hole when the fridge sensor came through.
Mounted the fan and controller on one of the useless strips they give you too hold things on the shelves, just fits on the shelf no fixing required. Set initial temp to 6 deg.
For the internal fridge fan, where does everyone put the temperature sensor? The bottom seems obvious place?I asked which one as there are loads of similar ones for sale. If it is the same as mine a AL8010F I've scanned them for you.
I put the temperature sensor in the fins near the top on my fridge, but after a couple of years use the cheap Chinese controller packed up.For the internal fridge fan, where does everyone put the temperature sensor? The bottom seems obvious place?
Also, some of the links are to products no longer there, and my techness isn’t good enough to spot the same ones. If anyone has a list of fan/controller from Amazon/ebay etc it would be appreciated.
I connected the supply to the terminal block on the back of the oven.Hi Lenny......I am just in the process of following your lead with the internal fan, can i ask where you picked up the 12v feed from, for info i also have the RMD8505 in a Hymer and if you were to do the same project again would you consider fitting 2 internal fans?
Thank you lennyI connected the supply to the terminal block on the back of the oven.
don't think two fans would make much difference.
