I think you misread my post, I was joking. My payload is 1220kg.260kg that's generous
Marquis have a 294 in atm on 3500kg with a staggering 210kg payload![]()
Mickey
I know sorry you were referring to previous post who said 260kg when intact its 210kgI think you misread my post, I was joking. My payload is 1220kg.
Mickey
I believe this is the Sri Lankan approach to overtaking. Collisions are neither drivers fault, they just happened to arrive on that bit of road at the same time.I'm the same with overtaking. I just close my eyes and hope it will be OK, been doing it years without a problem.![]()
That is for the vehicle, but it does not get around the C1 licence problems which for international circulation are governed by the weight limits set in the various Treaties and which have 140ish signatories who would have to agree.
Geoff
IMO not practical to buy a Motorhome with less than 700 kg payload.
I think your emoji seems to be on characterWhy? Which bit of my post did you not read where I said that I weighed the motorhome as soon as I got it and it was almost exactly as specified in the literature.
Autotrail use +/- 3%No one as mentioned what weight the vans come out of the factory at.
There is a +/-5% tolerance in my experience most vans come out 100 to 140 kg over the design weight and this has to be taken off the payload. That would make a lot of the vans listed here unusable with a passenger let alone optional extras that most people have 100 to 200 kg of.
The only exception I know is Hymer our first two were 30 kg under present one only 16 kg over.
Does that include the wifeThe options & extras I fitted to my van come to around 245 kg.
Not a problem if there's water at the place your heading but defeats the object of having a motor home so your not tied to sites
Yeh but you are cheating if it is not a single carriagewayI'm the same with overtaking. I just close my eyes and hope it will be OK, been doing it years without a problem.![]()
Makes it tied to sites in which case they could reduce payload even more by not having batteries and just have it tethered to a mains.I run with an empty tank due to payload issues. I just put water in when I arrive on site. Don't see a problem with that.
Autotrail use +/- 3%![]()
Which is clearly why we need a Category, for "Motor Caravan" with a sensible limit under UK law. (the other 139ish can fend for themselves). (or fall into line?. I dont particularly care.
That is just options, i.e., 2 x extra batteries, TecTower, Comfortpack, front aluminium roller blind, auto gearbox, spare wheel etc., in fact may be over 300 kg but still gives me over a 1000kg payload.Does that include the wifeAlways something to get rid of, like water, if stopped for being a tad heavy - the dog stays though
Can't find any mention of torelance on their website but 5% is the European recomendation that all other manufacturers work to.Autotrail use +/- 3%![]()
Can't find any mention of torelance on their website but 5% is the Europeane recomendation that all other manufacturers work to.
It did notice it said weight with all water tanks drained & no mention of any fuel or gas allowance.
Also a lot of models they fit a reduced size fuel tank a pinddly little 60 Lt tank, how crazy is that in a Motorhome, the standard 90 Lt is small enough I still wish I'd gone for the optional 120 Lt.
Yip had 90 on my last one, 60 on the new one, agree, piddlyCan't find any mention of torelance on their website but 5% is the Europeane recomendation that all other manufacturers work to.
I suspect that Autotrail wish to avoid any further reduction in its payload figures as having a 77kg payload (205kg-128kg), before material adjustments, is not exactly great for sales:
P.S. wife only just over 40 kg.![]()
Only had to go to Kent for mine, she hasn't 'afe put on some weight 6st when we met, now over 7st.You're a lucky man Lenny. I had to travel to the Isle of Wight to get my wife but she's a skinny thing and it helps save on payload.
If I had chosen a local lass then I would have had to opt for the 5T chassis instead of the 4.5T version.
They make them big up here![]()
Here's a bit of trivia that might be interesting !!!
An Australian guy (who posts on another UK forum) has a 2015 Auto-Trail Tracker FB. He says, AT only export heavy chassis versions to Australia because the normal car license allows up to 4500kg.
Problem solved.......emigrate to Australia![]()
