My son brought me a Covid test kit as I haven’t been feeling that good since I got home.
Testing positive for Covid.
Wildbill
Wildbill
WimpMy son brought me a Covid test kit as I haven’t been feeling that good since I got home.
Wildbill
Won’t let it stop me it’s like a very bad coldOh thats not good, rest up and get well soon.
I have to live the track rod end as I have to take the bottom ball jont of to get the drive shaft out to remove the engine to rebuild the gearbox keep jumping out of third gear probably just the sincro mesh or a shim worn won’t know till i strip it downGet well soonest Bill and keep up the hard work on the jollybus.
Sorry to hear you’re still ill (wimp) and hope it shifts asap.
Don’t forget to do that track rod end nut up either matey, now you’re getting old and forgetful and all that.
More man hugs coming your way
Agreed, our 2023 MAN TGE dips flat but the previous VW T6 (2016) dipped left but was changeable on the dash to dip flat. Both LEDs.Was like that back in the 70's now they kick up to the right.
Some of th latest LED ones have gone back to flat dipping.
Probably the last time she will have this much work done on her if I can get another two years out of her that will do my and get sumthing a bit newerI think you have Indian ancestry, they know how to keep things going for ever.
You’re a better man than I am Gunga din.
Phil
No he’s not going back got a good job with another company.You clever thing wildbill,i would have loved to do car mechanics at school but there was only sewing and cookery,hope you feel better soon. Pampam,can i ask was it your son that worked at donni airport? And if it was will he be going back?
No brainer to take the whole lot out and split it on the floor. If you had a ramp and full access to the underside then doing the box only is often quicker which is why the garages often do it this way but having the whole thing out gives you great access and an opportunity to do all those other jobs.View attachment 926580
There’s still sand and dust from our Spain trip three years ago in the engine bay
Just tinkering with the idea to just take gear box out and leave engine in place
Wildbill
I do have an engine crane but it’s at the back of our storage containerGetting the engine out with the gearbox, its a crane job. On ramps with a jack, dropping the gearbox down is much easier anyways. Unless you need to work on the engine, I don't see why its got to come out.
Engine crate getting dug out of the container me thinksNo brainer to take the whole lot out and split it on the floor. If you had a ramp and full access to the underside then doing the box only is often quicker which is why the garages often do it this way but having the whole thing out gives you great access and an opportunity to do all those other jobs.
If the front crash bar unbolts you can probably drag the whole thing out in a trolley jack.Engine crate getting dug out of the container me thinks
Thanks for your reply
Wildbill
So it's your fault.Well I got the brake pads fitted and the new pipes on but no further.
I have not been well today should never have started today but got a bit done
I ordered some Covid tests yes I have tested positive.
Feeling like crap hurting all over nose blocked chest full
And coughing constantly sweating profusely
And it’s very hot today.
There’s a rather nasty variant going around apparently.
If I am no better in the morning I have to check in with the doctor in the morning if I make it that far
Wildbill
I have it in and out a few times over the years got my engine crane dugout.If the front crash bar unbolts you can probably drag the whole thing out in a trolley jack.
