heres one I found weighing in at under 200pounds
The bms job is NOT to regulate the charge, that’s the chargers job. The bms is the last line of defence, not intended to look after the charging. No ifs no buts.
Any charger with any lead profile with a absorb in excess of 14.4 and excess of two hrs, it will put strain on bms. The bms will go into cell protection over voltage like a yo-yo. Until one day, a tired transistor will pop, then the bms is will not protect the cells, the a cell or more is bound to take overcharge.
The charger profile should be set on the lower edge of the bms safety parameters, it will charge without triggering over-voltage. That’s the normal operating mode for daily cycling. Only very few first cycles may trigger a cell over voltage, that if charger is set high. Within few cycles the battery will balance and work wonderful.
Same goes for alternator charging, skipping a b2b, you are dumping unregulated charge into a lithium.
Each to their own.
As for original tread title, lifepo4 it’s been cheaper than lead for few years now. The way to calculate cost is to take into account total energy round trip for each battery, and cycles. A 100ah quality lead is good for 480 kWh round trip, 800 cycles. A budget lifepo4 100ah is good for bare minimum 2560 kWh round trip, 2000 cycles. A factor of 5.3 times more energy. But lithium can even double that with ease. So how cheap lead has to be to equal lithium? If you pay £400 for a 100ah lithium the lead to be on par it has to be £75 for a 100ah, and lug the weight for the privilege.
If you pay less than £400 for lithium, then the lead has to be even cheaper. The lead is already overpriced, and you receive it with partial sulphation any way.
Last time I bought lead, they were dry and vacuumed, inactivated for shelf life. The importer filled the electrolyte to manufacture recommendation mix 1.28.
I never bought batteries in stock, always something they don’t have so they can order fresh.
Switch it off before terminates the charge even better.Understand… I was merely stating that no harm will come; using any charger is perfectly okay. Just switch it off when charged, no issue then.
£186 Ecoworthy on AmazonAlso £195 fof 100ah ecoworthy on amazon.
I'm a tad upset right at this moment because it appears that my 470 amp-h capacity is fully full, it's only 4.45pm and the sun is still blazing away and is expected to do so for a couple more hours.
Oh well... never mind.
JJ
You didn't say that in your post, your encouraging readers to take chances with very expensive motorhomes with uneducated posts, unless you know what you're posting about you're better to keep silent. You may not belive this but there is liability even on the tinternet....Understand… I was merely stating that no harm will come; using any charger is perfectly okay. Just switch it off when charged, no issue then.
Your price equivalent calculator only applies if you're keeping the batteries to the end of their life. I suspect the vast majority are sold with the MH well before then. I would though pay a premium for something more convenient in terms of charging speed, holding charge when sitting, weight etc etc like lithiumThe bms job is NOT to regulate the charge, that’s the chargers job. The bms is the last line of defence, not intended to look after the charging. No ifs no buts.
Each to their own.
That's a bit harsh!You didn't say that in your post, your encouraging readers to take chances with very expensive motorhomes with uneducated posts, unless you know what you're posting about you're better to keep silent. You may not belive this but there is liability even on the tinternet....
No that works. I do have a lithium 3 stage charger as an extra, but rarely plug it in, I leave the cbe to do its thing (rarely) as I have plenty solar and b2b . Probably knocks 2 cycles off the battery over it's lifetimes of 3000 ....I have this charger and seems although optimised for AGM/LA the max charge rating of 14.4 would charge lithium as a direct replacement, I also have a 400w Victron solar set up connected along side so if not completely ideal could simply isolate mains charger and set solar charger to lithium profile, am I wrong with this assumption
Agree if this charger can’t charge over 14.4 which is its max output at 20amps seems pretty suited for charging lithium, but I’m not an auto electrician, this post was handy as I wanted to change to lithium soon on this assumption.No that works. I do have a lithium 3 stage charger as an extra, but rarely plug it in, I leave the cbe to do its thing (rarely) as I have plenty solar and b2b . Probably knocks 2 cycles off the battery over it's lifetimes of 3000 ....
Can we all watch?so I shall sit in a corner, with a dunces hat on and flail myself repeatedly as penance!
Can we all watch?
Right pig returning to Amazon I foundAmazon prime offer here!
100Ah £186
Is this per useable Amp cheaper than decent quality lead acid leisure batteries?
Disclaimer: I've no idea if these are any good but with Amazon, you can return easily if needed!
I still on acid batteries but some “knowledgeable Campsite Experts” tell me the charger is three way and can change on a computer over for lithium. Does anyone have knowledge about this?I am not a mind reader. How do I know you have a charger which can be set to gel? (My post says "You will almost certainly need a new charger." given that I do not know that information.) I am sure I would need one to get decent performance out of LiFePO4 on my van. It is cheaper for me to install a 2nd leisure battery for less than £100 rather than replacing charger and existing leisure battery.
You obviously have more experience of motor-homing than me now I have looked but that does not tell me that you know one end of a 12v system from the other. There are lots of people on this Forum that do not even know the whereabouts of their 12V fuse box!!
Chris
What make and model.of chargerI still on acid batteries but some “knowledgeable Campsite Experts” tell me the charger is three way and can change on a computer over for lithium. Does anyone have knowledge about this?
I'd rather pay a little more and get the economy Fogstar battery. I believe we even have an MHF discount available.
Drift ECO 100Ah 12V Leisure Battery
The Fogstar Drift ECO is your gateway to reliable, budget-friendly off-grid power. With a superb 100Ah capacity and 1250Wh of usable energy, the Drift ECO is perfect for powering everything from leisure applications like camping and caravanning to professional use cases like solar energy storage.www.fogstar.co.uk
Out of interest what’s the difference between economy and normal?
No heating. No bluetooth.Out of interest what’s the difference between economy and normal?
That’s a good read and very helpfulGood article here for anyone that has questions regards lithium charging
How to Charge a LiFePO4 Leisure Battery: The Ultimate Guide
Whether you're a seasoned explorer or new to LiFePO4 leisure batteries, in this blog you'll find plenty of valuable tips and tricks to keep your battery running smoothly, so you can enjoy your journey without any power hiccups.www.fogstar.co.uk
That Fogstar Economy 100 Ah LiFePo4 battery looks identical to the EcoWorthy and Renogy Core batteries of the same capacity. Are they all made in the same Chinese factory?Out of interest what’s the difference between economy and normal?
Found this on the reviews on amazonAmazon prime offer here!
100Ah £186
Amazon also have prime specials yesterday and today
Just a possible minor point on the “drop in replacement“ strand here. Some vans designed for lead acid have the mains charger come on automatically when EHU is connected and I believe they may continue to trickle when the battery is “full”. So, possibly, you’d be 100% reliant on the lithium BMS to prevent overcharging unless you fitted an “off” switch. Maybe, the same applies to a non-lithium solar controller on a very sunny day?
