Very helpful George oh:
hi Brian if the wheels are locked with the steering lock it is then controllable as a 4 wheel trailer, and the braking can be tested on each car to see if it needs any extra help like adding extra cable to the hand brake cable of the car to give more power to the braking, but most will be towing a small car which will have more than enough power from the overrun to be legal without the servo ..
FORDY
hi'
i must point out here that ALL twin axle trailers and caravans have a very short wheelbase in relation to their size so the turning effort is minimal.
two or three blokes can quite easily turn a twin axle caravan on its axis but try it with a car and you got no chance. four wheels in the middle:thumb: or one on each corner
ok, it will reverse in a straight-ish line but reverse or drive forward,with the steering locked, round a t juction and your front tyres will shred in no time as they are being pushed/dragged sideways round the corner but they want to go straight ahead. if ,on the other hand ,you allow the wheels to castor ,at least going forward, the front wheels will follow the correct track but going backwards they will ALWAYS turn to the opposite lock due to the front of the towed car being pushed the wrong way. ie- reverse left, front of car pushed right due to rigid "a" frame, car steering, in effect, thinks its turning right so turns to right.
the rear of the towed car will still turn left as it should but the front will scrub as its in the wrong lock.
over short distances this would be negligable and you should have enough power to overcome the friction but to drive with the steering locked means the tyres will never follow the correct track as they will always try to go straight ahead and will scrub forwards and backwards
it,s impossible to reverse without some tyre damage hence trailers have a very short wheelbase to minimise tyre wear.
as for brakes, i doubt if its possible to get the correct leverage to apply the servo brakes, without vacuum, to full efficiency. try this. find a gentle slope, stop your engine and pump off the vacuum, roll down the slope and see how much effort is required to stop. (make sure your handbrake works)
now for autoreverse brakes. the only way i can see of acheiving this is some type of electric selonoid, perhaps a pin to go through the sliding hitch, to lock the hitch triggered when reverse is selected, just an idea.
im sure someone out there can see my point.
john.
