Yes, it had the NHS icon on top, the pharmacy forwarded it. And yes, it was the tunnel.Did the txt indicate it was a NHS test ?
According to the French and UK Gov. website a NHS test result is not acceptable. No reason given.So why would the French border official question it, it says NHS and says negative.
That was a test for which the result was reported by a third party, ie not you, so no possibility of it being falsified by you which the ones you do solely can be.When I visited a free walk in L.F. testing station a couple of weeks ago, before any testing was done I was walked through how to register on the NHS Covid 19 App. then I took the test and about 40 minutes later I received a Txt message from the test station with the test results. There is no way I could amend this so do find your post a bit odd.
Again a third party confirmed the result, not you, I suspect if it was a NHS free one that you performed and reported the result for it would have something on it to indicate as such and may therefore not be accepted.They accepted mine and wifey's which was done at a local pharmacy but was free. We just showed them the NHS text on the mob to the French border control, no quibble. The fact that it was done at a pharmacy would I suppose show it was the third party but it said nothing different so how would they know.
But it was accepted. I suspect the French border control was even more confused than I. I am not complaining.That was a test for which the result was reported by a third party, ie not you, so no possibility of it being falsified by you which the ones you do solely can be.
Not easy to proveReturning next saturday 3rd July. We've booked a pcr test at a lab in Neufchatel en Bray, but now I've got the issue of sorting out the 2 and 8 day test in the UK. It seems we can do a home test from Boots or the like, but have to show that we've booked it when we cross over. I can do that the day before, then we should be back home in time to receive it, as it takes 48 hrs to deliver. So that'll be three tests each when we have had both jabs. Ridiculous. We have not been in contact with anyone in France.
Not trying to. I'm just p*ssed.Not easy to prove![]()
CheersNot trying to. I'm just p*ssed.
Yes because you did not submit the result yourself, it was done by the pharmacy an independent third party with no benefit to themselves to make it negative or positive therefore fully trusted (not that you're not trustworthy but obviously some people aren't).But it was accepted. I suspect the French border control was even more confused than I. I am not complaining.
Lucky me, managed to book same test's in different location and within 48hrs of departure. Can only assume original confirmed test cancelled because it was booked for a Saturday Morning.Bugger! Just got an email from Boots cancelling our Antigen tests. Well and truly screwed now.
I don't quite get this ! When I walk into my local free testing station, I have no control what-so-ever over the result of the test. After taking the test in front of the tester, the swab is handed to him and that's me finished and on my way. Forty minutes later, or so I get a txt with the test results. However it clearly states its an NHS test result, so not acceptable for travel purposes. Nothing to do with a trust issue as far as I can see. Its never been made clear to me why a NHS test result is not acceptable to the French border force. It is what it is !Yes because you did not submit the result yourself, it was done by the pharmacy an independent third party with no benefit to themselves to make it negative or positive therefore fully trusted (not that you're not trustworthy but obviously some people aren't).
May I ask, When you went through the border checks in the UK on your way to France. Did both the UK and French border check your Antigen test or perhaps just the French before getting on the train ??But it was accepted. I suspect the French border control was even more confused than I. I am not complaining.
From what you have written it does look like some are paying for tests when they do not need to. What bearing paying for a test has on it’s authenticity I really cannot understand. A test is a test as far as I’m concerned.Just to confuse this point even more, the actual wording on the Frence Gov. website states the following.
2.2. Health control measures
All travelers coming from a country in the orange zone must present to the transport company and the border control authorities a negative PCR test dating from less than 72 hours before departure (departure of the first flight in case of travel with connection) or a negative antigen test less than 48 hours before departure (departure of the first flight in case of travel with a connection). Children under eleven are exempt from testing.
Vaccinated travelers must also present:
Nothing here about NHS tests not being accepted.
- a sworn statement attesting to the absence of symptoms of covid-19 infection and contact with a confirmed case of covid-19;
- proof of vaccination status.
On the UK Government website it states
You should not use the NHS testing service to get a test in order to facilitate your travel to another country.
This is not a mandatory statement and I also wonder if it was aimed at the PCR test when first put on there web site.
The mind boggles ? Are we paying for Antigen tests when we don't need, to cross into France ?
Your not alone with that view.Just my view but I don't think the NHS should be paying for testing just to allow people to travel. NHS Scotland don't pay for yellow fever vaccinations (and probably others) and I don't really see why this is any different.
I am fairly sure that it was only at the French Border Control just before we went through to the parking area for the train. We had not been asked before that, I was thinking we were through and was not prepared so got up to go to the back to find my phone, which of course was on the dashboard anyway. Carol slid across and showed HER phone, he readily accepted that, then asked was mine done, we said yes and he didn't even look. So it was cursory at best. But I have to say there was hardly anybody there, only one other camper that I saw on the train, and it was only the 2nd or 3rd day that access had been allowed anyway. Frankly, I wouldn't blag it again, and I only chanced it then on the basis that I was prepared to be turned back. The border control looked thoroughly bored and unsure.May I ask, When you went through the border checks in the UK on your way to France. Did both the UK and French border check your Antigen test or perhaps just the French before getting on the train ??
It just adds to the quagmire of doubt and confusion. A test is a test, and should be valid as such. The amount of money they are throwing around at testing, offering kits to people who only want something for free and have no intention of using it unless really necessary, the cost of a few used for travel is minimal compared to that. Allowing it would create clarity. And most travellers would be happy to pay a sensible amount to the Government to avoid these chancers and quick money sharks and scammers making a fortune from the melange. A whole new market has opened up creating wealth out of a pandemic. It is causing doubt, confusion and unnecessary stress.Just my view but I don't think the NHS should be paying for testing just to allow people to travel. NHS Scotland don't pay for yellow fever vaccinations (and probably others) and I don't really see why this is any different.
We entered Spain 2 1/2 weeks ago at Santander and the only thing they were interested in was if we had pets, didn't look anywhere in motorhome at all. Although we saw Plymouth side checking some commercial vans.MITHRANDIR and any other of you guys that have travelled UK to EU since the end of March.
What was the feeling / expectation of the EU customs guys as regards you taking your 'goods' into the EU. I'm thinking things like bikes, electrical equipment etc etc. Did they ask how long you intended staying in the EU or did they ask for a list of equipment or anything?
Asking as we hope to return to Spain in October and are thinking what our situation is as regards 'importing' equipment etc!
Thanks for that. I'm thinking a NHS test result would be acceptable but will pay for the Boots test just to be on the safe side. I might also take the free NHS test and offer this up at the crossing just to see if it is accepted. I would then let Funsters know so as to save them an unnesseccery expense.I am fairly sure that it was only at the French Border Control just before we went through to the parking area for the train. We had not been asked before that, I was thinking we were through and was not prepared so got up to go to the back to find my phone, which of course was on the dashboard anyway. Carol slid across and showed HER phone, he readily accepted that, then asked was mine done, we said yes and he didn't even look. So it was cursory at best. But I have to say there was hardly anybody there, only one other camper that I saw on the train, and it was only the 2nd or 3rd day that access had been allowed anyway. Frankly, I wouldn't blag it again, and I only chanced it then on the basis that I was prepared to be turned back. The border control looked thoroughly bored and unsure.
There are two main ways to get an NHS (lateral flow) test performed:
- via a kit which you obtain and use yourself and the result is known only to you with no third party (independent) intervention.
I agree with you, and what you say makes sense.My take on it is if the test done was done and the (negative) result confirmed:
- by you personally (as in 1. above) then it should not be accepted by border control as the result has not been verified by someone independent and people do tell porkies.
I see where your coming from and this is now making sense However, when you get the test result where its free and done by a tester the txt message you receive has some test codes with it and these are inserted into the Gov. web site and you receive confirmation about the test result. This is my understanding of what others have said and I will find out first hand come Friday when we take ours. I'm leaning more and more to this being accepted by the French border staff as there is nothing on the French Gov. website to say a NHS test result is not accepted. I'll let you know how I get on when we cross over.I agree with you, and what you say makes sense.
However, you can report the result (in fact the instructions say you must report the result) on line then you get a text and an email back telling you what you've reported. These messages merely give your personal details and the result "Your coronavirus lateral flow test result is negative. It's likely you were not infectious when the test was done" followed by a load of advice. There is no indication that this is a self-test that has not been independently verified, so no border inspection could identify it as such.
- a walk-in test where you use a kit they provide which you give back to them, they check the result then send it to you via text (possibly informed in other ways too but I'm not sure).
There is also obviously those which you pay for which are also independently verified but that's not what we are talking about.
- by a third party (as in 2. above) then it should be accepted by border control as the third party would have no reason to 'fudge' the result.
