Fogstar Drift App
Mar 30, 2022
2,139
2,603
Swift Suntor 590RL
Anybody having problems with the app ?
I received 2 x 105AH Fogstar Drifts today.
I down loaded the app on to my phone but no matter what I do my phone just searches and searches and doesn't connect.
I have also down loaded the app on to my tablet but that won't connect either.
I have Bluetooth and location turned on on both devices and have uninstalled and re-installed the app several times on both devices but still no joy.
I can connect to other devices via Bluetooth no problem.
Solution2
Due to slight differences in resistances due to manufacture and even temperature, and electricity always takes the path of least resistance there will inevitably be one battery that drops quicker them the other my two Aolithium batteries rarely discharge at exactly the same rate there is always a slight difference, but not enough to cause me any concern.
According to the app only 1 battery at a time is discharging.
I put a 5amp load on the system and 1 battery showed it had a 5amp load on it and the other battery showed no load on it.
I would have expected both batteries to have shown about a 2.5amp load on each ?
I wouldnt know one way or the other .I have seen some negative comments in the past none that i could quote i just thought as Lithium batteries were on your radar you would have an opinion on them, maybe you should look if for nothing else but to be well informed
Unfortunately it’s a minefield out there, some good some bad, I’ll stick with my Exide Gels for the moment…🙂
Oh I didn’t think of that…🤔 still, if I was selling stuff for motorhomes then I’d be on here like many other traders are… is it a lot..?
There are arguments both ways. They do have a facebook group as well as their usual communications method. As a business you have to decide which platforms to be present on based on demand.
You can't be on all of them otherwise you would need a dedicated staff member trawling them constantly 7 days a week.
That said, there is quite a captive audience here so I suspect it would make good business sense to have a presence on here.
Yes I've seen them now. Parameters
To be fair to Fogstar, on Friday they did offer to replace my batteries but he said he couldn't see the point as they'd never had any problems with their app and he thought the problem was with my phone and tablet and not the batteries bluetooth modules.
Now I'm not so sure.
Although the other app they sent me, Xiaoxiang, does work ?
Hi headlight, are you saying you can connect with the Xiaoxiang app? If that is the case then it probably is an issue related to the Fogstar app. Sorry if I missed that information from an earlier post.
If this is the case, then just use the Xiaoxiang app. My favourite is the Overkill Solar app. Fogstar just use a standard Xiaoxiang BMS (complete with poor balancing functionality) so there is no advantage using thier app. In fact I believe they hide some parameters so you are probably better off with one of the alternatives.
Steve.
Steve.
Yes the Xiaoxiang app connects fine, the Fogstar app won't connect to any of the 4 devices I've tried.
I'll just use the Xiaoxiang app for now.
When Fogstar release their new app, which apparently is soon, I will see if that will work with my devices.
I find the SoC in particular a bit difficult to read sometimes on the Xiaoxiang app without reading glasses. It's much easier on the Overkill Solar app. So if you find the same issue give the Overkill app a try, I find it has slightly better functionality too, like providing Bluetooth signal strength for example.
I've got a Victron smart shunt fitted so I will be using that and it is probably more accurate than the app.
Really all I wanted to use the app for was monitoring initial charging at home and cell voltages to see how well they were balanced and maybe to check the cell balance every now and then.
I can do that with the Xiaoxiang app.
i am sorry but a higher energy BT module would take weeks and weeks to drain a large lithium battery. we are not on about a 100ah lead acid here.
billy
But that's the reason they use it.
Lots of threads on here about people Sorning, draining down for winter, storing their motorhome until Spring.
Not everyone uses theirs over winter.
Not used my van for a few weeks, put battery on charge and if seems the balance function is now not working, well the cells don't flash on the app anymore. There has been an app update. Has anyone else noticed this now? I've tried resetting the balance on the app to no avail.
Might be a dull question but were the cells out of balance by the amount needed to trigger balancing in the settings?
18 days in and I have still yet to manage to connect to the app.
I was at the motorhome yesterday and my phone couldn't detect the app.
Not sure the effects of a full power bluetooth function and internal heater would help those folk with external shunts to keep their SOC accurate. OK if you can turn it off I guess
The heater only works of the charger the battery doesn't start charging until it is up to temperature so shouldn't have any effect on battery drain.
Im noticing that when people have shown the settings on here, there are a number of variations. Some are sert to balance from 3.3v others 3.45v for example. Im sure there will be other variations in settings and it would be good to see the correct best practice settings fot all the settings so we can check they are all the same.
I have now lost the 3rd temperature reading despite it being turned on in the BMS settings.
Yes but the shunt thinks the power used by the heater is charging the battery - and doesn't know about the BMS use of power for BT.
That is a very good point!
I guess the only way to re sync is to charge to 100% and synchronise the shunt? Do we know when the heater is working on the Fogstar?
Not been away in the bitter cold since fitting ours to test it.
You should only take note of the balance reading when the battery is fully charged.
Yes probably right but the heater probably won't be used very often so overall fairly negligible. Just need to sync to shunt when charged to correct it.
Whilst battery heaters should only use the incoming charge to power the heaters there have been reports of some of them using internal stored power leading to unexpected flat batteries. It seems that a few may be sensing a small charge from winter solar and turning the heaters on using internal power. The heaters are using more power than the solar produces.
Yes absolutely, its just another factor to trap folk like me who become infatuated with every number reported!
Fogstar say the battery doesn't start charging until up to temperature so it shouldn't really happen. Probably down to how well the BMS is configured.
Well my 300ah fogstar was installed back in September have used van several times have usually check app to ensure charging is ok and it is.
i think sometimes you can get bogged down with to much information and worry about things that you don’t need to🤔
As long as it’s being charged and holding enough power let it do its job and stop worrying😊
I'm not sure there's a single set of settings that will be optimum in all cases, for example fogstar told me they use 6 different bms versions across their range. Maybe useful for people to post the settings their particular battery (make and model) came with for others to check against, so we can check for anomalies?
