- Jan 31, 2016
- 2,244
- 4,219
- Hymer B534 DL (2017)
- Well travelled
And how do you make the horizontal cut that forms the lip before the hatch bit is removed? And bear in mind both lips (floor and hatch) have to be made of plywood.
You make one opening at (say) 150mm dia for top and 130mm for bottom assuming two pieces of ply laid one on top of the other ?? this should give you a lip all around of 10mm. I've done this for openings in floors for bathrooms.
Thickest ply I've seen and used is 18mm, either structural or hardwood Birch etc. if Hymer floors are 30mm then why not 18mm and 12mm bonded together ?
