does the engine run ok, then you rev it, then, when it returns to tick over it surges???
Don’t worry about keeping us informed. That’s what we (me) want.Changed the dpf control valve and checked there was vacuum getting to it when the engine is running. Engine starts and is fine for two or three minutes then starts to hunt on tick over, if you slowly open the throttle it chugs until you reach about 1500 rpm. Have yet to give her a good run and hopefully early next week can do ten to fifteen miles at 2500 to 3000 rpm if that sounds about right. Really do want to get this sorted now as not happy about long trips until she sounds right. Sorry to keep popping up but kind of loosing confidence in the van at the moment.
While the throttle body was off I tested the egr valve using a vacuum gauge which showed no vacuum leaks. I changed the electro pneumatic controller which sits above the engine centrally and has the two vacuum pipes, one from the servo vacuum side and one to the egr valve itself. I have checked there is a vacuum reaching it and also that the pipe to the egr valve is not blocked.Don’t worry about keeping us informed. That’s what we (me) want.
You did check your EGR whilst TB off? Did you apply vacuum and test EGR again?
You say the DPF control valve is that what you mean?
Keep us updated ,I feel your pain as i am having similar issues at the moment and it sounds like plenty people have had the same. Keep your chin up it will get sorted it s all good information for usChanged the dpf control valve and checked there was vacuum getting to it when the engine is running. Engine starts and is fine for two or three minutes then starts to hunt on tick over, if you slowly open the throttle it chugs until you reach about 1500 rpm. Have yet to give her a good run and hopefully early next week can do ten to fifteen miles at 2500 to 3000 rpm if that sounds about right. Really do want to get this sorted now as not happy about long trips until she sounds right. Sorry to keep popping up but kind of loosing confidence in the van at the moment.
You need the proper software. Is your van a ducato or peugeot?How can I do that?
The code also suggest possible throttle (pedal) malfunction. You can test the position of the pedal using some software to rule that one out.Thanks will check my reader and have a look.
Will run diagnostics tomorrow using a garage friends better kit. Still think it’s a sticking egr but hoping a thrash with a good dose of cleaner helps. In honesty with the faulty throttle body I was driving very gently to get home from France which wouldn’t have helped.A failed/sticking EGR, a gummed up MAP sensor, can also cause incorrect MAF sensor readings.
A good few drives will be a good start in your diagnostics as they can require a few drive cycles so set its parameters.Will run diagnostics tomorrow using a garage friends better kit. Still think it’s a sticking egr but hoping a thrash with a good dose of cleaner helps. In honesty with the faulty throttle body I was driving very gently to get home from France which wouldn’t have helped.
Remember that your throttle pedal, has no connection to the throttle body (unlike a petrol engine). You throttle pedal, is controlling via electronics how much diesel is injected into the cylinders. It doesn’t alter the air flow, or control the flap inside the TB. The TB is only operated when the EGR is operated, and when you shut the engine off.Another bulletin on the palace gates…. Took her for a twenty mile round trip on the motorway keeping in fourth and fifth at 3000rpm or just above when traffic permitted. Slight change in that when the lumpy tickover starts a quick throttle blip seems to cure it for a while. If the engine is on idle and the lumpy tickover starts if you open the throttle very slowly the lumpiness gets worse until about 1500 rpm then clears. It’s very hard to tell if it is the low revs or the throttle position causing it, I think I favour throttle opening position as you could just feel a unevenness in higher gears and that sort of rev range or a shade higher.
Will put it on a better grade obd reader tomorrow to see if there is anything there although the management light never came on.
Onwards and upwards.
So would that tie in with clean pick up when you floor it as assuming TB wide open and lumpy at low revs when either it’s too open or too closed? Have a feeling the egr is looming. Thanks for taking the interest.Remember that your throttle pedal, has no connection to the throttle body (unlike a petrol engine). You throttle pedal, is controlling via electronics how much diesel is injected into the cylinders. It doesn’t alter the air flow, or control the flap inside the TB. The TB is only operated when the EGR is operated, and when you shut the engine off.
To be honest my own reader doesn’t but heading Friday to a friend who runs a repair shop with better kit than mine. Will let you know.The TB doesn’t really do too open or too closed. It’s either open or closed on old basic stuff like ours. Modern stuff different.
On tick over the TB should be fully open. If you then gave it a BIG rev (TB still fully open), stop reving, then the EGR would open, and the TB closed, all this happens fairly quickly and then this remains for 3 mins (from memory). This is so the engine can use the fuel you potentially just shoved out the exhaust, and the TB is there to stop the clean air, so engine sucks via EGR cooler. The TB then returns to fully open, assuming all is work as it should.
Lumpy tick can be a sign of failed EGR.
Only other thoughts.
Have you looked at your injector /cylinder balance figures?
It reads like you have a cylinder that is missing, and a few higher revs are carrying a weak cylinder (one that isn’t getting the correct air fuel mix). But I’m only going on what I’m reading.
Can your reader do cylinder or injector balance?
Just thoughts.
I assumed that if the dpf valve was stuck then the butterfly was being told to do something about it but that may be a bit simplistic. My friend has the kit to cancel codes so can try disconnecting. As for the blanking path my only concern is the emission test on the MoT. Having seen industrial areas of China compared to the amount of miles I do yearly……..Do you have the ability to turn off /clear fault codes?
If you do, try disconnecting the TB, and see how it runs. This will bring on a fault code so you need the ability to clear it.
If the TB is closing at the wrong times you need to know why? Because it wants close it, or is it because something is faulty.
How bothered are you about keeping vehicle standard, and keeping the emissions stuff?
