- May 23, 2023
- 115
- 171
- Timberland Destiny
Fitted a new scuttle valve which made no difference, did check the pipes for leaks but will try reversing them just in case. Also tried the old valve again just in case the new one was faulty but no change. Thanks for the reversed pipes info.On my 2007 2.3 Ducato, there is 2 rubber pipes going to the valve under the scuttle of which you write. It is very easy apparently, according to others, to put these the wrong way round and even if correct, it is advised to replace this valve at the same time as the TB because, it has been working overtime try to rectify faults on the old TB + check there is no holes or leaks on the 2 rubber pipes.
I have, so far, had no problems with my old TB but have been carrying a new one around for the past 5yrs just in case?
The advice in the first paragraph, is advice I've read from MMM magazine experts, not from personal experience.
Good Luck!
