- May 23, 2023
- 107
- 161
- Timberland Destiny
Management light came on after a very minor misfire that lasted seconds. Got the code read and it is the butterfly regulator, it only happpened after rain and when going over a bumpy part of the road. I fiddled about to see if anything was loose and sprayed with WD40 then started the engine few times. Next morning the light was out for a good few miles, stopped and went for a walk. When I restarted the light was on again but the motor running fine.
So in the camper van in France at the moment, tempted to drive it until either it remains the same and the engine runs fine or it gets worse and there is a definite fault to fix.
Having a bit of a dither as to how serious the problem may develop or just carry on with care. Is this a common problem?
Any experience in this problem would be appreciated.
