Explain this!! Electrical drain overnight! (10 Viewers)
May 7, 2016
7,920
13,440
West Sussex
Malibu Van 640 LE K
Since 2003
Here is a wild theory for those who really understand these things to pull apart.
EHU plugged in and runs out of credit - Multiplus switches to inverter mode - Inverter provides different AC using out of phase 115V down positive and negative wires - EHU still plugged into bollard where negative wire is earth bonded - Inverter sending 115V to earth - 12V battery powering drain to earth.
Answer, unplug the EHU as soon as credit runs out?
20,105
33,403
Answer, unplug the EHU as soon as credit runs out.
I don't understand it but like the idea all the same ;)
WESTY66
WESTY66
6,779
17,534
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
I know you & electrics are you sure🤣
Go through all the timer settings.
It off at the off switch! That said I’ve just turned it on and when it was last used it was whilst on hook up and was set at 2kwh but surely if it’s turned off and the screen is black, it’s off altogether 🤷‍♂️
56,097
164,236
I can't see that happening but he is in Germany like all European countries outside the UK they use double pole switching so both neg & live would be disconnected when the bollard turns off.
56,097
164,236
I think it's a electronic switching on the Alde so you could have an intermittent fault.
This is assuming you can power the Alde from the inverter, I wired my van so heating can only be power by incoming mains not the inverter.
WESTY66
WESTY66
6,779
17,534
South Yorkshire
Can you run the heating from the multiplus? I had my heating on a separate circuit to the multiplus so that mistake couldn't be made
I’m assuming that when ehu is plugged in it works from the mains! Would it run through the Multiplus when on ehu?
Jul 7, 2021
1,914
6,892
dont own one yet.
So I rolled up to an aire yesterday, 56% on the batteries (600ah lithium) I was next to the leccy bollard which had €1.99 credit on it so I plugged it in and began charging up to around 80%. The weather was atrocious so I put another €2.00 to bring it up to around 100% and that was around 8.00pm. We went out for dinner and the balance was €0.00 BUT left the plug in, came back and watched two hours worth of tv (12v) and went to bed, still with ehu lead plugged in! Woke up this morning NOTHING that’s 240v plugged in, only usual phone charging and 12v FF in garage, alde OFF, fridge on gas and my batteries was 26% so it’s used around 65-70% overnight!!
Can anyone explain this??? Lenny HB RogerIvy anyone??
😱😱😱, that is not ok, also why was you’re charge so low when you arrived at the Aire, shouldn’t your BtoB charger have charged your batteries to a much higher level whilst driving or did you only drive for a very short time?
56,097
164,236
All incoming mains goes via the Multiplus, the Multiplus will run in bypass mode until the max current from the bollard is reached (depending on your Multiplus settings) . When you exceed that current the inverter turns on and makes up the difference.
If you were on a 6 amp hookup running a 2kw load the inverter would need to supply approx 35 amps at 12v.
56,097
164,236
Only a 50 amp B2B with 600ah of batteries.
Dec 31, 2010
2,851
6,506
Sunny South Shields
Frankia Platin i7900
If you wire all the 230v side through the multiplus you can control the threshold to when assist turns on better than when you have say the fridge and heating separately as the multiplus doesn't know how much power these are using so could still trip the ehu.
WESTY66
WESTY66
6,779
17,534
South Yorkshire
How about.. Pay a euro and plug in to ehu. When the time is up check the settings and see if inverter has switched on. Check everything while still plugged in to see if theres a draw.
Right these three might have the answer.
Sooooo I’ve just run a check with my settings on the alde!
Things I don’t know.
1, Soc at bedtime
2, was I running alde on multiplus whilst the credit had run out before I turned it off?
Things I do know.
Nothing 240v plugged in at bedtime
Alde off altogether at bedtime
Fridge on gas.
So with the settings I had on alde and I’ve just replicated it whilst on ehu, the multiplus is doing its job perfectly in that it’s topping up the electric with what’s coming in from the bollard, so even with hook up there’s a deficit, so if the ehu had run out of credit the deficit and would have been far greater a draw through the multiplus hence depleting the batteries!
Oh and when I turned off the alde, it was OFF with no current being drawn👍
I think RogerIvy makes a good call doing a check on Soc and relevant things plugged in before going to bed👍
Well IF this has been the case it’s a lesson learned👍
All charging up now, up to 53%
WESTY66
WESTY66
6,779
17,534
South Yorkshire
Haven’t hooked up since some free electric at Carthago last Thursday and have only been driving for an hour and half tops each day (not every day) solars not been too great so it’s where I expected it to be👍
WESTY66
WESTY66
6,779
17,534
South Yorkshire
Nail on head👍👍
Jul 7, 2021
1,914
6,892
dont own one yet.
1, Soc at bedtime
Things I do know.
Fridge on gas.
You need more batteries😇😆😆😆😆
Al n Val
2,633
6,844
West Yorkshire occasionally
Rapido i1090 Distinc
since 2018
53, that’s my no Ade
Thinking about what’s happened to you last night, it’s a Cathargo thing
It wouldn’t never happen to a Rapido 🤣🤣🤣
Hopefully 🤞🤞🤞
MichaelT
3,918
8,262
Colchester
Carthago I 143 LE
Since 2016
The Alde is about the only thing in your van that would take that amount of current. Even the fridge running from the inverter wouldn't use that much.
Have you got the timer set on the Alde for hot water or heating & you have cocked up the settings?
At least you have the Multiplus and can get a decent charge back into the batteries quick. (my reason for fitting one MichaelT)
Yeah but you wouldn't be on EHU would you and if you were you wouldn't be so stupid to run your heating off batteries all night would you?😀
