No more than any other part of the intake air circuit from the EGR recirc. Worst affected are the intake manifold and throttle body as pictured by me earlier back.That heat exchanger looks a likely site to clog up with residue too.
The Bri Nylon background adds a nice touch though Andy.EDIT I appreciate the picture through a plastic back may not convey the quality so here is a hopefully better shot?
I'm concerned, the item on the intake manifold should be the throttle body. The EGR should be on the exhaust manifold. I don't know trannies but be aware.Whilst delving into the engine compartment of my Transit today to find said valve, I found it right on the top of the inlet manifold( dead handy that) and I also noticed that the actual inlet manifold is plastic of some type which could be damaged it the exhaust gases got too hot like the Ranger mentioned previously, I will now check further upwind to see if there is a cooler fitted to the pipe at the exhaust end.
No throttle body,mine is a Tdci and has no flowmeter. It is on the pipe from the intercooler to the manifold and has the vacuum pipe leading to it, I take it is there because that is a much cooler part of the pipe as on the exhaust end it would cook otherwise.I'm concerned, the item on the intake manifold should be the throttle body. The EGR should be on the exhaust manifold. I don't know trannies but be aware.
Really it is very hard to get wrong given the size/shape of your blank plate.
I've been over to look at mine again this morning as I had to dump the fresh water anyway.
Access to my EGR is complicated due to being left hand drive. The cab air intake is right on top of it so I will have to strip that out first .
I've looked again at the intake manifold and to be honest the worst of the gunge is around the flange and will be easier to just take it off with a finger in a rag with some carb/brake cleaner. The rubber pipe that brings the mix of fresh and recycled air to the throttle valve seems to be pretty free of any deposits.
I just need a nice day now
Gordon Bennett!No Jock that big massive box and all the cardboard is purely anti parcelfarce protection for the iddy biddy gasket.
The blue box is just a flat piece of card for display hanging the gasket.
