Riftzoner
E bikes are ridiculously expensive compared to cheap Chinese ‘twist n rip Chicken chaser’ Mopeds but hey that’s the leisure industry for you Being an avid cyclist myself with (if the wife’s reading) only one or two bikes (I lie, okay lots of bikes) including a full on e-mountain bike. Yes, there’s several things to do.
1-install a good quality alarm with an external protective loop. There are several on the market, Phantom, Vanbitz, Outsmart The Thief to name but three.
2-Remove the battery, this makes it a 25kg lump of scrap metal with some additional expensive bits attached (brakes gears etc) but never the less, an ebike without a battery doesn’t carry half as much value, as the batteries can cost up to £600 to replace & then there’s aLeo a charger required.
3-carry it in a good quality carrier Thule or the like which is physically locked to the vehicle via the tow ball or bolted onto the vehicle which in turn has lockable securing knobs with which you lock the bike. I also use a lockable reinforced lockable tie wrap (Hiplock) through the frame & carrier & yes I’ve had a bike stolen from a locked Thule Classic carrier. It just required some meathead with enough determination to rip it out of the locked jaws. Believe me it can be done.
4- Remove the pedals & leave in top (stiffest gear). I also reverse & re install one of the pedals so that the pedal will hit the frame when anyone attempts to move the bike & unless they have either a pedal spanner or Allen keys they ain’t going anywhere & at best would still only have a one pedalled bike
5- Beyond this point any further deterrents will probably be illegal
As with any deterrent the the name is in the title ‘Deterrent’ & that’s all it is. You basically want to make it so awkward for the would be thief that they’ll leave yours as being too much bother & move on to look for easier pickings. Remember, they’re basically Human Jackals, much preferring easier pickings.
As for the previous member who expressed shock at ebikes costing £4000, please don’t check out Santa Cruz Bikes as they’re ebikes can set you back £12000! Yes, that really is Twelve Thousand Pounds
