For my bike I have put an eye bolt through the rear wall under the bike rack and lock the bike to that
With pedals off I get an ebike and normal bike in the back of our VW Crafter PVC, first things out when we get to site. If there is a nearby sturdy tree I chain them up with two locks around both bikes and tree and cover them. If no tree I have a screw in heavy duty security ground anchor. Impossible to remove with cables through it. Amazon product ASIN B00GLR7CLQHi, this is my first post in the forum, and it's a question that has been intriguing me.
We want to buy our first MH soon, but as it will be in the 6m - 6.5m length, it almost certainly won't have a garage large enough to store two eBikes.
We're still trying to choose between a PVC or coachbuilt, but that is another question entirely!
So how can you keep expensive eBikes secure when you are in the MH particularly as ours cost about £3k each? Storing them in an awning won't be sensible, but would a bike rack with the bikes covered be safe enough?
I'd really welcome your thoughts and experience.
Chris
We have one of those cables and it brings peace of mind, I would add something like a Tracker to an eBike I know there are some who say trackers are a waste of money but locks chains can be broken and it’s just adding another level of security. <Broken link removed>.....or a strikeback alarm which has a bike loop. Set the alarm and when the loop is broken off goes the alarm and if the thieves have been smart it will have been the last thing to go.
It is very hard to defend against - either a garage (which you do not have) or inside, which is not very convenient.
SimplesThere was a big problem down at Roquetas De Mar with cycle theft on the wild camping area. Twice we had straps and cover cut. We use two large chains and padlocks to to secure the bikes to the bike rack.
In the end I took the front wheels off of a night and we were not targeted again.
Great advice we do the same but also remove the saddle with the quick release.We do similar and have also fitted removable pedals which clip off in seconds - all to make the bikes less attractive and a little more difficult to steal.
Aerialmark What tracker do you have for the MTB?I agree with all of the above plus a good strong bike cover. We have two eBike which are worth about 8k and when on site and not using them we put them back on the rack with 2 Abus granite D locks plus a abus cable lock joining them together. Then on my mountain bike I have a little movement alarm which is activated by a key fob and also a tracker. It is all then covered by a thick material twin bike cover I bought from Yorkshire covers. Passers by cannot then see what’s underneath expensive or cheap. We have had no problems in two years. I think it’s all down to common sense as to where you park and also a little bit of luck that you are not “ in the right place at the wrong time “ Also my Cube bike can disable the motor by removing the display unit and only that unit can switch it back on again as it’s coded by Bosch. Not that a thief would know that or even care. Having my eBike has changed the game for me as far as motorhoming is concerned and I would not go anywhere without it. Good luck.
But if you buy a piece of crap then it won't meet requirements and if it doesn't meet requirements then it is poor value for money.Holy moly, £4000 each! No wonder they get nicked if people will pay that much.
Our Honda scooter was £1070 at six months old, takes 2 at 50mph and probably won't get stolen, I certainly don't worry about it.
The best strategy if you must have a push bike is to buy a piece of crap, some are that bad they don't need a lock![]()
No substitute for a garage in the a Motorhome if you are going to take expensive bikes with you.
Was the insurance through your house insurance or a stand alone policy?2 expensive e-bikes on a thule carrier, which is locked to the towbar, and has lockable clamps, litelock gold standard lock which pass through the bike and then through the towbar, silver standard frame locks with cable extensions through the front wheels, and bikes alarmed if we leave the van with the bikes on, and insurance that specifically covers them on a bike carrier, batteries removed and kept in the alarmed motorhome, they could still be stolen but not too quickly and I have taken just about as many precautions as are reasonably possible.
We have electric bikes on the back of our adria and have done so with other previous Motorhomes for 14 years.With pedals off I get an ebike and normal bike in the back of our VW Crafter PVC, first things out when we get to site. If there is a nearby sturdy tree I chain them up with two locks around both bikes and tree and cover them. If no tree I have a screw in heavy duty security ground anchor. Impossible to remove with cables through it. Amazon product ASIN B00GLR7CLQ
We have a Hymer Exsis 414I at 6 metres. Garage probably big enough...swallows 2 mountain bikes relatively easily.A great suggestion. Thanks. I think we would have to find a used one!
