Sorry to hear of your woes Alastair, however, you really need to go to a Fiat Professional agent with your Chassis and Reg Nos, as they can identify which gearing was fitted, ie, number of teeth.Thanks to everyone for this info. I've just got home to Cornwall after suffering Ducato disease yesterday, north of Glasgow. Fourth gear all the way, 55 mph and I'm knackered! As this thread is quite old now, can anyone recommend a current UK source of parts at reasonable cost?
Once you are sure what parts you need Alastair, try these people for Fiat spares.Thanks Jock - I'm planning on doing a strip-down at the weekend to see what's what, but will do as you suggest tomorrow. I had a look on e-bay earlier and someone is offering kits for the 2.8. Mine is a 1998 2.5 but as you say, until I know what is inside there isn't a lot of point in looking for bits!
Thanks again - I'll update when I've begun the surgery!
Alastair
It was a cheap and easy way to upgrade a four speed box, to a five speed box, and if I knew back then, what I know now, mine wouldn't have failed either.total poor design of the gear box in my view, but a common fault.
That's exactly how I would describe the parts that came out of our gearbox too. We found the broken bits on the inside of the end casing, as a couple of years previous, I had attached very strong magnets to the casing, which picked up all the crap and swarf.The gear is a 58X35 and the teeth look very worn. The synchro has a couple of chipped teeth and although it has never been reversed I'm not going to risk it but will add it to the spares stock...
Hi Alastair,Up and running again! The parts from E-bay were the correct ones. I've attached a picture of the drain plug - I've attached an additional magnet on the cover plate in case there are any bits left after flushing out.
Alastair
