JockandRita
- Aug 2, 2007
- 12,398
- 168,745
- N+B Flair 8000i
- Since May 05 (Ex Tuggers).
Northernraider. I have highlighted this before on your Flair thread Tam, and will mention it once more, ie, your loss of turbo power is not necessarily related to the malfunctioning of your turbo waste gate. The slightest of leaks in the turbo boost pressure can cause the loss of power. Ours was experienced going uphill, and like you when trying to overtake trucks. It turned out to be a pinhole in the turbo boost hose..........only detectable by the diagnostic kit of the Iveco Bus Workshops in Blanes.
Although advised by phone by my mechanic pal back in the UK, I would never have found it myself.
Tighten up the jubilee clips on those boost hoses first, then check carefully for the tiniest of leaks under boost pressure.
Good luck,
Jock.
Good luck,
Jock.
