These days they're asking for phones lol.Pencils and Crayons Tam, the only way, the majority of kids appreciate it and adults tend to get the message! ( mind you mobile phones may have changed the expectations! )
The PCB with the sockets is normally held on to the main PCB with just a blob of sloler each side. I've repaired a few stregthing the joint with a bit of tinned copper wire they a do of Epoxy.I might open it up though see if anything obvious
Yeah it was a loose wire on the switch , sorted it now though .The PCB with the sockets is normally held on to the main PCB with just a blob of sloler each side. I've repaired a few stregthing the joint with a bit of tinned copper wire they a do of Epoxy.
That's why I only buy the aluminium body ones now.
Looks more like he's trying to work out how to get inside. It's pictures like that that would stop me going to Morocco, it's just so sad, poor skinny thing.He'd already had a bowl of food but wanted blu to come out to play
Possibly but I think he just wanted blu , i had to hold on to her collar as she was ready for jumping out the window.Looks more like he's trying to work out how to get inside. It's pictures like that that would stop me going to Morocco, it's just so sad, poor skinny thing.
You don't need a generator specialist, a lawnmower mechanic would suffice, but I reckon the carb main jet will be gummed up by the sound of things ? I think you'd be well capable of giving the genny's carb a quick strip down yourself Tam, get yourself a can of carb cleaner and and a tooth brush just follow this guy's lead !
If you can buy carb cleaner, give the air intake a quick spray with it first and see if it will fire up on that, if it does, it'll be blocked jets.
Ah, got you. Yeah, some of those sets have a fuel pump that's initiated by crankcase pressure and they're renowned for the diaphragm going hard and stopping pumping. Best of luck with it all the same.Yeah did all that before ...had it running then it stopped again . Fuel pump or choke isn't working or something it's just not drawing fuel anymore
But it's not been used for 12 years.I thought the Dometic tec 29 had Honda engines and were ultra reliable?
Yes I forgot that bit.But it's not been used for 12 years.
Northernraider who was it that offered to clean the carb for you, might be worth a visit when you get back to ukYeah did all that before ...had it running then it stopped again . Fuel pump or choke isn't working or something it's just not drawing fuel anymore
The carb was all cleaned and it then ran fine.. changed plug , filter etc and fitted new sound deadening, refitted it and it wouldn't run.Northernraider who was it that offered to clean the carb for you, might be worth a visit when you get back to uk
I'd have to get one made but not sure I'd have time now ,trusting that you had a good day with your four legged family and lots of cuddles too for your birthday..
did you manage to find a fancy cab pelmet or still looking?
Had I thought about it earlier I'd have had someone do it when I was in Tafraoute.. I could have had it done in Agadir but didn't want to stay there long enough to have that as ideally I wanted pelmets round the cab and all the curtains in the van done to match.that’s a shame..
I think it would take a good few days for them to be done .
Buy who knows maybe I'll get them done sometime later .
Yeah maybe ... who knows I might ask in tetouan if I see one of the places that does upholstery etc. I can always give them all the original curtains to copy ... but the pelmets I wanted for around the cab would have to be custom made .My guess is they would be relatively quick Tam…
My ‘go to’ tailor in Shanghai would have a suit made overnight with fabric I’d chosen, ready for final adjustment fitting, final tweaks completed again overnight, so two days in total… great service! Sadly the suits have shrunk as I’ve got older!![]()
I removed mine easily enough with the use of a trolley jack underneath the base, once you have disconnected the fuel pipe and associated electrical connections just jack it up slightly to take the weight off the outer case rails and slide it out. Even better if you have a small piece of wood to spread the weight moreThe carb was all cleaned and it then ran fine.. changed plug , filter etc and fitted new sound deadening, refitted it and it wouldn't run.
But it isn't sucking the fuel In so like I said I expect the pump is knackered. But it needs completely removed again to sort that and it's not a one man job.
Yeah I had it out before ... I don't have a trolley jack though I've only bottle Jack's and won't be as easy with them.I removed mine easily enough with the use of a trolley jack underneath the base, once you have disconnected the fuel pipe and associated electrical connections just jack it up slightly to take the weight off the outer case rails and slide it out. Even better if you have a small piece of wood to spread the weight more![]()
Worst case scenario is they're not that expensive in the UK either .My guess is they would be relatively quick Tam…
