- Jul 28, 2010
- 15,475
- 20,764
- Rapido 7090F 3 litre 160
- May 2010
Very good John, I'm sure it won't be detrimental but the Status foam gasket is supposed to be used without sealant.
Whats the benefit of using this rather than a mifi or is this some sort of mifi? Thanks
If you plug it into one of these you wont need a driver for it.
http://shop.motorhomefun.co.uk/product/wifi-repeater/
Can you put this in the resources please. I think it might be very handy for others including me to come back to at some time in the future.Clearer picture 192.168.168.1
Changed from 192.168.2.1
Make the change in advanced settings and save
It doesnt have a built in router. What makes you think that?
http://www.motorhomeplanet.co.uk/archives/5086
Or if you don't want to go through the roof, do what I did, but an aluminium window cleaner 3 tier pole and fasten it to tow bar. I also installed a waterproof RJ45 box under the MH which is linked to the router inside the MH so I simply plug it in and can twist the pole 360 degrees to get the best receptionJust for you matey
http://www.yachtingsoftware.com/usb...GbCRvU77n0u9fSGkedxXLdhbPXX3cdCT8TxoCFWDw_wcB
That is what motorhomewifi originally sold with that antenna and until recently was sold in @Jim shop
If you copy the theme of this thread you will have wifi access as good as anything else on the market. If you look at their new products you'll see that going through the roof is the way to go as if I didn't know
Thanks @Addie. I was inspired by @Techno but wanted the added benefit of more height. The wire passes down the centre of the pole and with it fully extended gives me enough to the plug into the waterproof RJ45 box fitted under the van which in turn is routed into the van to the router. Granted I have to fasten it to the tow ball in all weather but there has not been a place where I have not been able to pick up a wifi signal when fully extendedAndy is semi-responsible for inspiring me to produce a retail version of this, which we called the iBoost Connect.
Unfortunately, it does cost a fair bit more then a home brew with almost none of the satisfaction of creating your own thing, but will suit those who want an off the shelf solution. I might actually break even on the tooling cost if I'm lucky
We do it as a full kit with a roof foot and also as a retro-fit into an existing 'Status' type TV antenna if yours is redundant through having a Satellite TV system installed.
BROKEN LINK
I do like the telescopic mast though @dspsuk999 !
