- Jul 28, 2010
- 15,475
- 20,764
- Rapido 7090F 3 litre 160
- May 2010
Not sure what you mean by existing? The whole thing is new.so does the existing pole pull out easy please?
Sorry see my EDITok, thanks anyway, it wasn't posted by you, I copied it to show you what ours was like.
View attachment 48011I have one of these, copied from an earlier post but the same as ours.
I wondered if the pole would come out to do what you have done except the hole is there, we dont use the AERIAL
I've ordered a new longer piece of pipe as the extra 150mm I can accommodate may prove useful
750mm long pipe is only £8.99 delivered.
I wish I could find another of these now obsolete panel antennas.
Hopefully Adam "Addie" will try this with a current model panel
I'm going to mount it like yours on the outside through the roof.
BTW if anyone uses the Motorhome WiFi antenna as I have, according to Adam it isn't meant to be outdoors permanantly. Mine has a liberal appication of silicone on all joins and seals, including tha RJ45 inlet.
Malcolm
If you do, remember: ....
I may be trialling a new offering from Adam in the near futureI have one of these too. Are you in a position to compare with the latest Antenna sold by Adam ? I'm thinking of upgrading but do not see the point unless the improvement is significant.
I know you have the tube how's it coming on?I have the iBoost as you see in the photo. I have ordered the mount to drill hole in roof ( already done in photo ) all I have to do is get the tubing ordered and I will start the fitting ( my photo's of install will follow.
I got a remote keypad , arrived today.Hi Andy
We've got the same alarm system, works well, if you haven't already got them we can highly recommend the key fobs for this system, saves having to set/unset using the main box.
I have the same one, (earlier one pictured) its neither robust or waterproof but works well.. just open Heki skylight and pop it on roof.
