Think it needs to be in a covered area and dried thoroughly, before resealing, as I understand it.Is it a big job to seal the bike rack, wouldn't you be better doing it yourself, probably the cost of a tube of sealant , and save all the agro?
No no no no. Anything but siliconesilicone
I think I would have tried to fix a bit of plastic over the area with tape as a temporary fix while it was being investigated. I bet if it had been siliconed over lowdhams would deny all liability (and I bet they still try to) saying someone else had bodged it.lTo be honest sealing around the camera is a 5-minute job. I would have done that straight away just to stop it getting worse. I appreciate it might have clouded the issue initially, but once the source of ingress was known. Adding a bit of silicone would have been my first priority
Yeah. stuck now. Lowdhams saying it's the factory fitted camera leaking but can't repair it because they're not a Knaus dealer anymore. And the whole back wall needs changing.But SMC are saying its not the camera but the bike rack.
My 4d Makingtrax is that I think you could be pushed back and forth between them for ever. Having seen it are Lowdhams going to admit it that they misdiagnosed and it was the bike rack they fitted? I would get a detailed quote from SMC for doing what they consider needs doing. I would then write to Lowdhams giving them a reasonable time to respond and give them the opportunity to fix it and see what happens. In the interim I would put the smallest amount of sikaflex you can on it to stop it getting any worse.
I haven't touched anything Jim (apart from covering the camera in clingfilm), playing it by the book and complying with all the warranty rules. Not that it's got me anywhere now SMC disagrees with Lowdham's assessment of where the damp's coming in.To be honest sealing around the camera is a 5-minute job. I would have done that straight away just to stop it getting worse. I appreciate it might have clouded the issue initially, but once the source of ingress was known. Adding a bit of silicone would have been my first priority
I don't think you are stuck, but its going to take a bit longer, I think if you can get SMC to confirm their belief that its the bike rack thats causing the problem and you then give Lowdhams the opportunity to repair it and give them a timeframe, then they have two choices, rectify the faulty workmanship or fight it. If you re not asking them for a new backwall its not really a big deal so they could decide it would be better to offer a goodwill gesture. And if they don't then pay SMC to do it and chase after Lowdhams in the small claims court. I'm no expert ( obviously) but this doesnt look like one worth fighting for them and they would do better to just settle. If having done all that then (god forbid)its still leaking then SMC will have taken ownership and will be required to rectify it.Yeah. stuck now. Lowdhams saying it's the factory fitted camera leaking but can't repair it because they're not a Knaus dealer anymore. And the whole back wall needs changing.
SMC won't repair it because they're saying it's not the camera but the Lowdhams fitted bike rack that's leaking and therefore not a Knaus dealer warranty job.
A bit Catch 22.
Will see what Lowdhams have to say about SMC's diagnosis before deciding what to do.
A bit Catch 22.
Sound advice IMHO and the route I’d take.
Getting SMC to do the job would be a good move forward.
Except trying to get your money back will be extremely difficult. Dealers will fight it as my own experiences have shown. Personally I would not go down this route until a specialist solicitor has given his advice.Sound advice IMHO and the route I’d take.
Sadly I have, and if the OP wants to keep the van the CRA is the way to go. It is down to the dealer to fix, and if that means sub contracting to elsewhere so be it. Trying to get money back through the small claims court is fraught with problems, with nothing guaranteed.I take your point but I believe the op wants to keep the van.
SMC are saying they can dry the van out and fix the problem, as I understand it, then all is good.
Any future issue is then the responsibility of SMC and if the issue turns out to be a warranty issue they could deal with it as a Knaus dealer.
Just my thoughts and fortunately not had this kind of issue to deal with.
True. But it maybe 9 months before they reopen and all that time the bike rack might be leaking into the back wall. A real dilemma.May I suggest you contact MSC for their thoughts first, and maybe even Knaus before you start playing with anything.
By the sounds of it Lowdhams sound like the sort of company that would argue that you have possibly made things worse and that they are no longer liable.
Assuming they have only shut down because of the coronavirus.
Contacted SMC yesterday afternoon, they are still open. The body shop manager said that they were contacting motorhomers to cancel upcoming work. Which is more than Lowdhams have done. Had no reply or confirmation from them about the work they said they'd do in drying out the back wall on March 30th.May I suggest you contact MSC for their thoughts first, and maybe even Knaus before you start playing with anything.
Never knew having a pup would be so knackering Rob. It's been a long time since our last dog, so you forget.Hope it’s sorted eventually,on another more upbeat note how’s the hound doing ?![]()
He said that a bead of silicon across each of the horizontal bars of the bike rack would stop further ingress and would be worth it under the circumstances. It may dry out underneath of its own accord.
So thats what I'll do, little choice really.
Wouldn't putty crack when it dries out, with the movement of the van. What about a bead of acrylic sealant or that stuff 'Seal n'Peel'? Trouble is I've no idea how temporary this will be.Probably best not to use silicon, it will stop any other sealant sticking, very difficult to remove completely. As a temporary measure you could run some sticky tape over it, even old fashioned window glazing putty would be better than silicon.
It uses an acrylic glue I see. How hard will that be to clean off after x months, compared to a small bead of silicon.Greenhouse repair tape is very strong and sticky, look it up on ebay.
