- Jun 2, 2023
- 61
- 45
- Benimar 143
- I'm a newbie (ISH) 2022( type 2 VW's and caravans 1980 s to 2022)s
Has anyone been told damp checks are only being carried out on the floor at the habitation service nowhere else .?
I queried my last two damp checks on habitation service, one on a motorhome and one on a Basecamp. Both reports showed no figures recorded. Was informed that “readings are no longer recorded if they are between 0-15% as no cause for concern”. Probably a let out if you come back later with a higher reading showing damp somewhere.Has anyone been told damp checks are only being carried out on the floor at the habitation service nowhere else .?
Just before buying our MH, I bought one of these. Very efficient and does the job a treat.I wonder if a good damp detector is needed for us to check.
I'v bought a gas detection device for gas leaks and a damp detector device.I bet the cost of the habitation check has not gone down
I recently viewed a Burstner Lyseo at Marquis and was shown a pile of paperwork from the original owner, which included 2 x damp check certificates from Southdowns, but the most recent one expired in August 2024.Not really. I had a major damp repair done under warranty. Also had a fridge replaced. Various other more minor nigglesl this was within the first 2 years of a brand new van.
Chainwheel2 does Benimar have any specific requirements for their damp warranty? How long is their damp warranty for?
My experience is with my Burstner purchased from new in 2021. Habitation warranty is very separate from the damp warranty. Habitation warranty is only 2 years. Damp is 10 years but requires a detailed damp report and 30 - 40 readings taken from all over the van. The only area not checked is the floor due to the construction of it. The report must be done by a Burstner dealer annually (at customers cost) and recorded on the Burstner database.
Knowing how specific Burstner are about the annual damp check, I queried it with Marquis and they advised that any damp issues would be resolved, either with them, or Burstner, but not to worry!
Marquis's 3 year warranty has a maximum payout of £1,000 in the first 2 years for water ingress or delamination, reducing to £500 in year 3.
Knowing this, I pushed the point with the sales guy and asked if the Burstner annual check had been completed to maintain the integrity of the damp warranty and he told me yes. I asked whether the certificate and report were available and he rather unconvincingly said, 'it has all been completed internally and not to worry'.
Needless to say, I walked away!
Non invasive damp meter. If something suspicious arises they may take a more invasive reading using some thin prongs.Hi everyone, I have a Hymer with an aluminium outer and inner shell, just wondered how these are damp checked
Carthago factory does a full water heavy duty spray test on their vans as part of pdi. They still want annual habitation checks including damp report for their 7 year water ingress warranty.I think Carthago is just a visual check all round now, they don't even put a hose on it anymore.
The water ingress check can be hived off as a separate check in order to retain the ingress warranty. The hab check is then optional depending on whether you feel it's a good policy to have that as well, personally I don't have the hab check, and we're now out of warranty period for the ingress check.Hi,
I have just had my 1st Hab check carried out £456
With the paperwork there is a plan showing 80 damp check readings...
I think expensive but needed to keep the guarantee.
KO
warranty possibly.I'v bought a gas detection device for gas leaks and a damp detector device.
Whats the point in paying hundreds of pounds for someone to tell you what
you can find out for yourself!!!!
After time, you know your van.....
That is BS just because it has grp external walls it still need a damp check.
That is because the internal wall are aluminium so can't be checked.I think Carthago is just a visual check all round now, they don't even put a hose on it anymore.
Carthago do not require a habitation check just a damp check to keep the 10 year water ingress warranty.Carthago factory does a full water heavy duty spray test on their vans as part of pdi. They still want annual habitation checks including damp report for their 7 year water ingress warranty.
