Compressor fridge (2 Viewers)
Mar 6, 2008
131
141
Spixworth
Van Conversion Moto-
We recently bought a compressor fridge after the nightmare 3 way Domestic 8505.
We decided on a VitriFigo C115 fridge without the freezer box.
Getting the old fridge out was the easy bit.We have a "slam dunk" door,so plenty of room. I removed some of the gas pipe then had the end capped under the van. Fitting the new fridge was err! not so easy as the fitting frame is a teeny bit big and will need some fettling later.Howevet,it looks good and works well ish!
Currently it runs for 1 minute then stops for 2 minutes. I have contacted Penguin who are the main dealers in the UK and they have said that as it is stopping the thermostat is working.We also turned the thermostat knob to 1/2 way.
Has anyone bought one of these fridges and can they confirm that their VitrFigo fridge do the same on/off routine as ours does?
Jan 19, 2014
9,867
26,224
Derbyshire
Elddis Accordo 105
since 2014
Mine is a kit I bought but with the original thermostat it did similar to what yours is doing. Is the thermostat phial fastened to the evaporator? I swapped mine for a vt9 auto defrost stat and it works now as expected.
Jan 19, 2014
9,867
26,224
Derbyshire
Elddis Accordo 105
since 2014
I put an electronic controller on it too and the VT9 stat is just a back up now.
Much better, lots of settings to faff with👌😎
Sep 26, 2013
4,257
5,291
Market Rasen
Since 2003
I fitted the C85 one and it works very well just turned on to halfway, it’s very quiet and cannot tell when it’s working or not.
Jan 19, 2014
9,867
26,224
Derbyshire
Elddis Accordo 105
since 2014
The VT9 thermostat has a fixed cut in temperature of 3.5°c no matter what it's set on, so the evaporator is always defrosted by the time the compressor restarts 👍
PeterE1947
Mar 6, 2008
131
141
Spixworth
Many thanks Richard n Ann. I noticed yours is a Dometic fridge,I have no idea where to fit it to our VtriFigo fridge. Thank you any way for the heads up.
