- Dec 19, 2020
- 4,725
- 14,572
- Carthago Compactline
- Since 2017
Adams Morey, PortsmouthWho did the work please.
The consensus is that if the water pump is driven by the cam belt, and the work involved to replace the water pump is the same as replacing the cam belt, then do it. It may not be listed as a requirement of the cam belt job, but more a "safeguard". There have been cases of water pump failures not a long time after changing a cam belt, then you are back to another hefty bill for repeating the work again. Its peace of mind, up to each individual to make the decision.
Maybe but the only warning the driver will get of bearing failure is a screeching noise just before the engine self destructs!
Leaks you will get a longer period of notice, before the inevitable.
I would say Fiat/VW/Ford trained people would know far more than a back street grease monkey on a modern day vehicle given all the electronic technology that drives everything and are more likely to have the correct tools for the job. I am not saying the prices they charge justify that however on a newer vehicle probably a good investment when coming for resale, on a 20 year old van then probably a different story.Once out of warranty I wouldn’t go near a FIAT main dealer. (Or any other main dealer).
There are plenty of “corner garages” who still employ people that really know what they are doing rather than module changers, at half the price.
We are talking about a water pump and cam belt change here are we not? Not much electronic technology there.I would say Fiat/VW/Ford trained people would know far more than a back street grease monkey on a modern day vehicle given all the electronic technology that drives everything and are more likely to have the correct tools for the job. I am not saying the prices they charge justify that however on a newer vehicle probably a good investment when coming for resale, on a 20 year old van then probably a different story.
combined brake and clutch master cylinder?Plus, why does Fiat, not put the renewal of clutch fluid on any of their schedules? Its changing could forewarn of clutch problems before the clutch fails completely?
I had many years ago a VW Jetta with 1600 D engine, horrible car, I did a lot of miles and thought I just drive it into the ground and do not spend on it anymore, did over 70.000 k without any servicing, never anything wrong with it, sold it with more then 200.000 k on it………..There has always been a "factory" set time for all work on vehicles (from at least the early 60's which was my start of knowledge on the subject), in those days it was known as bonus time, which was the difference between the factory hours and how quickly you could get the job done, the bonus time was split between the company and the mechanic, but the mechanic was always responsible for any comeback.
I personally feel that the system then started the downward spiral from what I call a proper mechanic to fitters, we were taught and trained to diagnose and repair most faults and problems, so if a car came in with gearbox problem, remove it strip it out and repair it not remove and replace with another one.
I'm very aware times and values have changed but as you point out not much has changed with the charges made to the customer.
Don't forget modern vehicles are far more reliable and sophisticated than then and require less frequent visits for routine maintenance.
Hi L' Hoboand I cannot see a single thing wrong with it, can you? no tracks, no marks, nothing!
PS. Do you mind saying where it was done?
DerryW , Thanks for that, he sound like a good guy, I'm not a hundred miles away and there maybe a time when I need someone like that, take care!Hi L' Hobo
The work was done by Eddie Payne Fiat Alfa specialist in Bury St Edmunds. Eddie's view was "at 5 years and 24000 miles the water pump really doesn't need replacing" my view was for less than £300 I would rather it was changed.
As a matter of principle, when I change the brake fluid, I tell the mechanic to change the clutch fluid at the same time. If it's black it gets flushed through too
About a 1/6 that price from my local man.. Around £2502011 2.3 l Fiat X 250. Wait for it............ £1,450.00
The only way to really ascertain if the price is ‘reasonable’ or not is to understand the Fiat workshop schedule hours for the job.
Yes but that’s just a rate question, in order to evaluate the value of the job, you need to know the hours. The only theoretical constant.It’s not the amount of hours set against the job.
It’s the amount of dollars they set against the hour![]()
Just to unnecessarily prolong a thread that started about cam belts, what many readers and some contributors on this and other forums don't know or forget, is that all motor vehicles are not the same.If it's black, you might need more than that as it's often a sign that the rubber compound is deteriorating somewhere in my experience, that's the reason I changed the clutch, master and slave cylinder.
Getting a pedal again was a pain and had to be reverse bleed!
I am afraid your Fiat friend was wrong. The Fiat Service Schedule for my 2015 Ducato based A Class tells me that the brake fluid should be changed every 60,000Km or 24 months, whichever comes first.This was when I discovered, from my Fiat friend, that its not on any service schedule.
I know a guy with a izusu pickup , it was under warranty so he took it to izusu for a service without asking how much it'd be , just a service , they found nothing wrong with it , £950£100+vat as a minimum hourly rate of which the mechanic may get £15.
Even when I bought my brand new Toyota Hilux pickup in 2004 it never saw a Toyota dealers workshop for anything.
That's not quite true. I sold tools to these so called grease monkeys and believe me there is not a lot of difference in general between ands and main dealer techs. The apprenticeships scheme by ma8ndealers has just about dried up. They now employ these so called grease monkeys, who have been trained by local colleges, tale them on and then send them on a 1 to 4 week course on how to use there cars. As for diagnostics some use after market devises, some don't. Likewise some independent garages use a thing called pass through, which gives them access to maindealer specific diagnostic software from the aftermarket devices. Then you have the techs who have left maindealers and set up themselves and often specialise in a particular brand.I would say Fiat/VW/Ford trained people would know far more than a back street grease monkey on a modern day vehicle given all the electronic technology that drives everything and are more likely to have the correct tools for the job. I am not saying the prices they charge justify that however on a newer vehicle probably a good investment when coming for resale, on a 20 year old van then probably a different story.
L' Hobo was referring to clutch fluid.I am afraid your Fiat friend was wrong. The Fiat Service Schedule for my 2015 Ducato based A Class tells me that the brake fluid should be changed every 60,000Km or 24 months, whichever comes first.
As I understand it brake fluid is hygroscopic and tends to absorb water from the atmosphere. That reduces the braking efficiency because water compresses more than brake fluid.
Agree but you said if the price is reasonable.
If the rate per hour isn’t reasonable![]()
