Can anyone give advice for a Burstner 747-2 Alde Heating system on roughly how much fluid it holds . I need to drain and refill?
EDITED A FEW TIME as I got further down hole...Thank you, that’s exactly how I have planned to connect but will similar fittings, I’m waiting to do it but still not sure which fluid to use maybe I’m over cautious there Glycol and another with Glycerine both should be ok.
If you hunt around you can find the right spec g13 for £45 for 20 litres which should be enough for the jobI just went to Alde Moosewerks who did the fluid exchange and a full service of the system for just under £300. Looking at the price for 30 litres of Alde fluid it might be cheaper to get them to do it.
I just want to be able to do it myself, if it breaks while I’m away then I can fix it etc. it’s not about the money like to take care of my Motorhome myself. Plus if you do it yourself you know it’s done right.I just went to Alde Moosewerks who did the fluid exchange and a full service of the system for just under £300. Looking at the price for 30 litres of Alde fluid it might be cheaper to get them to do it.
Just saying you don’t always get what you pay for theses daysI just want to be able to do it myself, if it breaks while I’m away then I can fix it etc. it’s not about the money like to take care of my Motorhome myself. Plus if you do it yourself you know it’s done right.
If you disregard the cost, you could liken it to living in a house in winter, would you feel more comfortable with a fan heater of full central heating.Reading threads like this one make me so very glad that I don't have (and never ever will have) a van with an Alde heating system.
Radiators, pipes and joints filled with liquid stretching around your motorhome...
Why?
(It's not, and never will be, a house.)
JJ![]()
I have Truma blown air and Truma/Aldi under floor/radiators in my van and I never use the blown air option, walking around barefoot in the middle of winter is greatI already have blown air "central" heating...
...and not a water pipe or radiator or house in sight!
JJ![]()
Thanks for sharing, I’ve made mine now but it’s the same just a different design same principle.
If that is what you think then OK I'll put it another way, on a cold winters day, two vans, identical in every way other than the heating system.I already have blown air "central" heating...
JJ![]()
We all have our preferences which we prefer I guessIf that is what you think then OK I'll put it another way, on a cold winters day, two vans, identical in every way other than the heating system.
From starting the Alde system will take slightly longer to achieve the set temperature, once at set point it will maintain without the fluctuations you get with Truma blown systems, an added advantage is you don't get the noise of a jet aircraft taking off when it is trying to achieve the set temperature, most people find the system nicer to live with.
It’s good to know you done your ownI did ours during the pandemic, buying the G13 concentrate and distilled water, both from Euro Car Parts.
At the time, it would have cost me considerably more if I had bought the premix bottles.
As I had to drain rather than flush the new fluid through, it did take me considerably more time to bleed the system fully.
Cheers,
Jock.![]()
Which I would have done, had the pressure from the small 12v pump not kept blowing the pipes off the flow and return adapters, no matter how much I tightened the jubilee clips.Andycap63 said that it’s probably better to flush the a drain.
So you had to fill it up by hand thenWhich I would have done, had the pressure from the small 12v pump not kept blowing the pipes off the flow and return adapters, no matter how much I tightened the jubilee clips.
Jock.![]()
You are not wrong.So you had to fill it up by hand then![]()
You are not wrong.
BTW, I can't believe that you have scribbled all over that nice hide furniture with a black marker pen, just for the benefit of others. OMG..............................
Cheers,
Jock.![]()
My Boss Lady would have said exactly the same.the wife would of killed me if I had. As it is she just said omg can’t believe you have it on the seats
