Can anyone give advice for a Burstner 747-2 Alde Heating system on roughly how much fluid it holds . I need to drain and refill?
A 747-2 Burstner holds 20 litres of fluid in the Alde Heating SystemA quick google suggests 12 litres
Quick edit. It suggest at least 12 litres.
Yes, so 12l for smaller vans, prob 15 or 16l for medium sized vans and 20l for the bigguns..make sense doesn’t it. Good job well done by the way.A 747-2 Burstner holds 20 litres of fluid in the Alde Heating System
Well done a job well doneI would be interested if any others take on the fluid change.
A Burstner 747-2. Alde Heating holds 20 litres of fluid.Once I’ve done the drain down and refill I will post just how much I used
I get what you are saying Tony, and I do carry a bottle of the G13 concentrate for topping up. However, whilst able to check the strength of the glycol's coolant/antifreezing properties, how do you check the levels of corrosion inhibitors? A genuine question BTW.If the fluid is antifreeze, you can test the strength with a hydrometer, I have never changed the antifreeze on my old Volvo XC60 not ever on a fleet of Volvo trucks they all had alloy fittings and some pipes never had a problem, we had a caravan with Alde system I did top it up a little once
I don't know, all I know is my 14 year old Volvo XC60 has never been drained, very infrequently a little antifreeze has been added, little I mean a cupful, where the loss is due to What I call normal, so very little oxygen is induced, so I assume that corrosion is not a problem, the other thing is when the Poster said I'd rather do it myself , as I know it will be done properly if you have had no training , how do you know it's done properly ? I was told on my Aldi system top up if necessary when I had a caravan, but there you go.I get what you are saying Tony, and I do carry a bottle of the G13 concentrate for topping up. However, whilst able to check the strength of the glycol's coolant/antifreezing properties, how do you check the levels of corrosion inhibitors? A genuine question BTW.
Cheers,
Jock.
A few years ago I asked an Alde technician (at a motorhome show) about retro-fitting their system to my Frankia, which had blown air. He said he'd always wanted to try doing that and we had a brief discussion about collaborating on the project, but I never took it any further.I have had Truma for years but now with Alde, there is no comparison. It is a pity that it cannot be fitted to existing vehicles.
Almost straight out of Dale Carnegie's "How to win friends and influence people" written in 1936 but still very relevant today in dealing with people, whether in business or just generally.I had my heating fluid changed by Alde at their premises in Wellingborough, which I thought was good value, especially as they checked the system and boiler over in the course of doing the change.
While I was waiting in their training room I noticed these plaques on the wall, which I think explain Alde's excellent service.
