Lenny HB
- Oct 18, 2007
- 58,142
- 179,535
- Carthago Compactline
Read the thread all will become clear.what Actually is the problem ?????
I was just referring to the ECU's failing, I thought they had got over the problem by 2018, but a 2019 van could have built in 2018 or eairler.I'm following the thread Lenny but there's no clear indication to what the actual fault is........high battery voltage........low battery voltage....fit another earth wire, etc...........mine came on a couple of weeks ago and it was none thats mentioned on the thread
I don't think it was ever a problem on the X250's only on the X290's.The thing is my last van was a 2011 auto trail chieftain that for twelve months I had no end of problems with the battery going flat until one day the alternator cooked the battery, Christ knows how many volts were in the battery when it was bubbling .....never had the air bag light come on though.
My van now is a 2016 carthago with no problems what so ever and the bloody air bag light comes on for no reason so I don't really get what crash data are saying ?
that makes things a bit clearer palI don't think it was ever a problem on the X250's only on the X290's.
Talking to a friend yesterday he said his airbag light kept coming on, I asked have you let the battery get low he said yes had to jump start it twice. Its a 2016 3lt.
I had mine replaced in under warranty and that was on a 2013 AT Mohawk so an X250I don't think it was ever a problem on the X250's only on the X290's.
We sent ours off to crash data and it came back with more errors than when it went to them. Not wholly impressed with them tbhI personally cannot believe that with modern electronics, Fiat cannot purchase and install a more robust ecu.
I have just had the srs ecu reprogrammed by CrashData. Probable cause of failure - low voltage.
I installed new battery and fully charged it before installing the repaired ecu. All was good for a few days but then the airbag warnings came on again. (I had waited for all dashboard lights to stabilise before starting the engine)
MultiECUscan says low voltage, again, and internal fault - B0100-49 . A check of the engine battery shows 12.8v. Terminals to ecu all clean.
Question: is there a definitive method of installing and protecting these devices or do I have to keep paying £90 to CrashData for a reset that may come back again in near future?
Van is a 2018 Fiat X290
The other rumour of why they fail is moisture caused by condensation. This generally doesnt happen in Ducatos sold as vans but does happen in motorhomes due to the extra moisture created by cooking and overnight breathing etc.
I have heard of people opening the unit up drying and then the unit is ok. So if you have the terminal code that says the unit is knackered it may be worth carefully opening it and drying it out. Look for signs of moisture on the PCB etc and dry out thoroughly then reseal.
It may answer the reason why repaired units from crashdata fail again, as they only reset them.
Also a new starter battery. For peace of mind.I hope you are getting the seller to fix the Airbag problem before you buy as they can sometimes be problematical to fix.
Mine failed soon after repair for getting through MOT. Crash data said it worked when it left them and the component failed not their workmanship. Have to agree. Due to send off again for this coming MOT.Mine has been to crash data twice @£80 each time... spoke to crash data to enquire regarding warranty as it failed again within a month of them resetting it... answer was no chance
decided to forget them and purchase a new one which is being fitted by main fiat dealer Monday 24th
So if you only fix it for MOT... does that mean you are driving around with defective air bags. as i was told by fiat professional that the airbags would not engage. with the red dash light onMine failed soon after repair for getting through MOT. Crash data said it worked when it left them and the component failed not their workmanship. Have to agree. Due to send off again for this coming MOT.
Will a new one suffer from whatever ?? causes problems?
The light is orange, Reading the manual orange lights are warning not stop driving immediately.So if you only fix it for MOT... does that mean you are driving around with defective air bags. as i was told by fiat professional that the airbags would not engage. with the red dash light on
My lights were red not orangeThe light is orange, Reading the manual orange lights are warning not stop driving immediately.
I really don’t know if the airbags would not deploy. If your Fiat service agent correct, surely they should make the light red?
I will find out!I guess the first point is what solar controller is currently fitted?
Depending on what it is will depend whether or not it is currently trickle charging the cab battery.
