Steve and Denise
After being locked down for so long I don’t care about fuel consumption just drive
exactly. I can't wait for the day when everyone who drives above 3500kgs or pulls a caravan has had appropriate training or even better regular assessment s. Be honest guys, there are a lot of terrible drivers in motorhomes.If you learnt to drive and successfully passed your test the following would have applied to making good progress.
What your examiner is looking for
The examiner is expecting you to
Driving faults recorded
- Drive up to the speed limit if road, weather and traffic conditions permit or at a realistic speed if not
- Approach hazards at a safe controlled speed without being over cautious or interfering with the progress of other traffic
- Emerge from junctions without stopping at give way lines if it is safe to do so or emerge at the first safe opportunity to proceed.
20 Progress
Appropriate speed:
Undue hesitancy:
- Crawls along at slow speeds on clear roads.
- Makes no attempt to achieve maximum speeds for the road when safe to do so.
- Reduces speed excessively when the conditions do not merit doing so.
- Makes slow progress through the gears in normal driving.
- Makes unnecessary stops at junctions and other hazards.
- Waits unnecessarily when it is safe to proceed at junctions.
- Waits for green light at pedestrian crossings when clear on flashing amber.
- Waits for other drivers, who are clearly giving way.
Dawdling on the inside lane on a motorway forces speed limit traffic that is making "good progress within the road or vehicle type limit" to move into the middle lane. In turn traffic is then forced into the outside lane and we end up with a long stream of vehicle in the outside lane. Lorries cannot move into the outside lane so get stuck in the middle lane causing even more congestion:
Completely agree with you. I was retested every three years whilst in the Fire Service both at normal road speed and on blue lights. This retest was initially a four day retest then reduced to two days. Always enjoyed my EFAD requals.exactly. I can't wait for the day when everyone who drives above 3500kgs or pulls a caravan has had appropriate training or even better regular assessment s. Be honest guys, there are a lot of terrible drivers in motorhomes.
Am I in favour or retesting? You bet I am.
I was in effect retested after 40 years when I took my C 11 years ago. What a shock, after 40-50k per year I was the most perfect driver, my instructor and the examiner just failed to see it!exactly. I can't wait for the day when everyone who drives above 3500kgs or pulls a caravan has had appropriate training or even better regular assessment s. Be honest guys, there are a lot of terrible drivers in motorhomes.
I think it’s going to come but more to do with reducing numbers on the road rather then safetyI think there should be some form of reassessment as we get older. As a fuel tanker driver we had a driving and operations assessment every year. It was done “in house” but we were expected to drive to DSA standards. Also 50 questions on the Highway Code and expected to achieve 90%.
We took it seriously as no driver wanted to be the first to be sent for retraining. I got a buzz when I got a high score.
I’m 69 and would ok with retesting.
I only dump the grey water at speeds of over 60 mph so it is evenly distributedIntresting that people on this forum think that motorhomers dropping grey water out give us a bad reputation, but in my discussions I find no one cares about that, but hate the way motorhomes and caravans are holding up the traffic as they pootle about at old fart speeds, completely unconcerned about anyone else.
Retests would certainly help to make the roads a safer place. Particularly retesting reactions would help some to make the decision about when they should give up their licence.
For those still meeting the required standard it would be a boost to their confidence.
Agree, same with piston aero engines. Get airborne without delay, spend the first hour at highest cruise setting. Same after an overhaul involving pistons.Actually with modern engines, the best running in is (and it has to be done in the first 20 miles or so or it won't work), completely ragging it flat out. Best technique is to put in in 3rd at slow speed and floor it to the red-line and then decellerate to low revs and repeat three times. This will result in the piston rings bedding in properly. After that, revert to normal reduced low revs for the next 500 miles.
Of course, manufacturers could never advise you to do such a thing, as the unusual speed profile would be somewhat suspicious (and, in fact, downright illegal) on public roads. However, you'll end up with an engine with half the oil consumption and get a good 1-2mpg better over the lifetime of the vehicle.
As the friars who tried to recolour their faded garbs found out at prayer ...It is but not like it used to be but old habits die hard
20 Progress
Appropriate speed:
Undue hesitancy:
My van is limited to 70 , the amount of times I've overtaken someone doing 63 in lane two who refuses to use lane one, then you look in the mirror and there they are in the blind spot at 70 so the two of us are now blocking the motorway so I have to back offI don’t mind that they are doing 50 so much, it’s when they speed up when I get along side and can’t go any faster as am already on the limiter.
Must be great to be perfectI belong to the “ looney brigade “ speed limit everywhere it appears to be safe.
My judgement of the capabilities of many drivers stem from watching antic in campsites, wife or partner has to get out to watch and indicate wildly when trying to mount their levelling ramps, after several attempts and revving the motor and slipping the clutch manage to go over the top or only get half way up and give up.
If the rest of the driving is like that no wonder they get out. It also makes me smile when I imagine the wife riding her bicycle along in front with a red flag.
I and I’v watched others do it, open the drivers door and lean slightly and watch your wheels, allow a bit for the movement when after applying the hand brake.
Konnon Fodder, I don’t know what is wrong with your V Line but we have no rattles and we do not have to even turn the radio up at 75-80mph (speedo) 71-75 (GPS ) wind noise does increase at 80-90 though.
Fuel consumption on dash read out since new and now with 9K + is 28.4mpg. That’s not bad from a 130 motor with a plug in ( Tune It ) module set at no 5, approx 160bhp.
In my optimistic opinion I think a modern turbo diesel is probably thirstier at low revs and being asked to slog when a gradient appears than letting it fall into it’s happy gaite.
My excuse is, driving with my foot at an uncomfortable position it gives me cramp in my ankle, well that’s what I tell my wife.
I’m waiting for the “ flack “ now from my irresponsible drivel.
BernieT
You've not driven an A class then?open the drivers door and lean slightly and watch your wheels,
Do what I do & have had done to me . Pull out, u alongside then indicate & start going back in.What he said except my limiter is set higher!!
Had a middle lane « 70 is plenty » road warrior do it to me three times on M5 yesterday.
Because yo would fail your driving test 50 years ago driving at that speed let alone now.This moan is a non starter to me. So long as vehicles are doing AT LEAST 50mph on a motorway how can anyone complain? Safer, steadier, economic, easier control in wind, easier to avoid obstructions.... So what if other vehicles want to go 60, 65 or 70? I am bored of the nob heads that consider 80 to 90 the norm because "modern brakes are better" and other twoddle....
I doubt that it would make a difference when they reckon that now there are 3 million who don't have a licence. add in the uninsured as there will be plenty who have one & not the other. nless they can police it better it will never work.I think it’s going to come but more to do with reducing numbers on the road rather then safety
They can't have it both ways. Yo fail a test driving at 30 in a 30mph limit. They can't the spot ****/cks on a course that that is acceptable.similarly anyone who has had the benefit of a speed awareness course will have been advised the speed limit is just that, NOT a target.
As above indicate & cut them off. Totally illegal here , it was made a specific offence here to accelerate if someone pulls out to overtake you.My van is limited to 70 , the amount of times I've overtaken someone doing 63 in lane two who refuses to use lane one, then you look in the mirror and there they are in the blind spot at 70 so the two of us are now blocking the motorway so I have to back off
There are lots of terrible drivers full stop,,both private and professional,,Cannot believe how driving standards have deteriorated this last few years..You are now frightened to go past parked vehicles with oncoming traffic because most seem to need so much room. I see cars stop to allow oncoming traffic where there is room for a truck to go through.Rant over.BUSBY.exactly. I can't wait for the day when everyone who drives above 3500kgs or pulls a caravan has had appropriate training or even better regular assessment s. Be honest guys, there are a lot of terrible drivers in motorhomes.
Cruise control set to 62 mph...
Then I go on back to make a cuppa & watch a bit of TV
