Swivel seat security (1 Viewer)
Nov 8, 2018
149
114
Peak District, Derbyshire
C class Dethleffs Esprit
Newbie, stayed on a few
Been watching this thread for a while and decided on the patriot which seems like a good solution for my van. Having drilled a 14 mm hole it's still a tad too small. Any suggestions as best way to widen, e.g. a reamer bit, hand file or buy a 15 mm bit ? TDA.
Two on Tour
10,434
52,045
Elddis Autoquest 175
Jul 1, 2010
3,214
35,019
SW Northumberland
Hymer B 588 DL
Since September 2010
If anyone has been sitting on the fence put off by the £50+ cost of the Oxford Patriot Disc Locks they are on offer today at Sports Bike Shop for £38.61 delivered, not sure if its a Black Friday one day deal I have just ordered one it’s a cracking price.
Oct 13, 2016
1,053
897
Grays - Essex - UK
Mercedes Hymer B680
Been moho’ing for a time now
Hi Stewart, (are you doing any of the rally’s in 2021?), I’ve got one on ours, PERFECTION, it’s just that I paid premium price for it, but no regrets, GO FOR IT!!!
Aug 15, 2014
2,588
3,487
Exiled in Yorkshire
Pilote 600L
Just ordered, many thanks (y)
Two on Tour
10,434
52,045
Have a look here,
He had obviously seen it on this MotorhomeFun thread as we were already fitting the Patriot lock to our swivel seat nearly a year before he uploaded it to YouTube. :giggle:
Pity he did not take note about fitting the 6mm washer rather than faffing about with the lock mounting bracket. :doh: :giggle:
Jun 7, 2020
15
12
Poole
Adria coachbuilt
Since 2019
On my Ducati swivel seat there is already a loop to enable you to put a padlock through. You have to look underneath but its standard. No need to drill seat base. i just put a heavy duty longer shank padlock through to lock it backwards. Takes two minutes.
Two on Tour
10,434
52,045
About the same amount of time to remove it with and angle grinder.
Leisure man
72
21
Hi I have fitted my disklok to my van and my friend said why don’t I turn my swivel seat around and drill a hole in the runner and padlock it in the turned around position so they won’t be able to sit and drive if they go to steal
It has anybody done this
Cheapest fix, drill hole through seat base the size of a 6 inch nail shaft where only you know where it is. Cut off nail head with 1 inch shaft remaining, spray nail head to match seat base. Drop through hole. Job done.
Jan 19, 2014
9,431
24,902
Derbyshire
Elddis Accordo 105
since 2014
Could do that as an additional, imagine how upset they're going to be after going to all the trouble of removing the disc lock and it still won't turn 😁👍
I fitted our disc lock a bit further round than in the video so the seat is more comfortable to use, ie your legs point down onto the floor rather than onto the bench seat 👌
Cal54
3,821
62,557
Southport, UK
Leisuredrive Renoir
Since 1996
Another fan of the Patriot lock. I took advantage earlier in the year of the warning stickers that a fellow funster had printed, and these are on the side windows. Great as a warning to ‘would be’ thief’s as I keep the blinds closed when parked up at home.
Ken Hall
42
91
Whitby North Yorkshire
2016 Carado T135
40 years
I've been securing my various motorhomes, by locking the seats back to front for about 15 years. Couple that with parking with the steering on full lock and a steering lock wedged so the wheel can't be moved and you foil attempts to winch it easily onto a low loader. I also drilled and pin the handbrake in the on position, again with a padlock. It stretches the cable a bit, but we drive it around every couple of weeks during the winter and the cable gets adjusted at the annual service.
6
62253
But you could say that about any type of security you decide to put on your MH. Surely its preferable to having no security whatsoever.
Reactions: TR5
Jul 14, 2019
274
190
Rapido 7086f
Hi anothet fan of oxford patriot just make sure you get the right Two different lengths of 14m/m pins
Ken Hall
42
91
2016 Carado T135
40 years
Thing is the thief has to have an angle grinder in his/her kit and a means of powering it, unless it's battery operated. The noise would wake us anyway.
Jul 14, 2019
274
190
Rapido 7086f
Hi I will have to start checking my spelling before I send answer that should have said another also missed Length out:rolleyes:
Two on Tour
10,434
52,045
If the security fitted is not much of deterrent, then what's the use of wasting your time fitting it ?
Fit something or multiple security devices to tax the mind of the would-be thieve or that will put them off in the first place.
Two on Tour
10,434
52,045
The number of times that people have had cars and motorhomes stolen that say they never heard the alarm go off, so an angle grinder in a cab with a closed door is not even going to be as loud as an alarm going off or the alarm noise is going to cover up the noise of the angle grinder.
As an example, a couple of weeks ago, the alarm was going off in the caravan two doors down at 11.30 pm. I wandered down and banged on his door to let him know and got no response. I tried ringing him, no response. After 20 minutes the alarm stopped and reset. In the morning he rang me and said he never heard the alarm and his bedroom is 5 meters away from his caravan. Turns out the mice had got in as the alarm went off again the following afternoon.
Ken Hall
42
91
2016 Carado T135
40 years
As I stated in a previous post, we have two alarms, one which is the Thatcham standard fitted by the dealer and another completely independent and concealed that triggers ,with either movement or intrusion and rings my mobile, so if I'm in bed with the mobile next to me, I will hear it. It has a £40 24GB data SIM with a lifetime of two years, so very inexpensive. I sleep very lightly and the slightest noise awakens me. In our rural village its dead quiet by 10 pm and we can hear owls, cats mating, and other nighttime sounds. If an alarm goes off, our neighbours hear and call whoever it belongs to, if it doesn't get silenced quickly. A bit old world here just outside Whitby, but very secure.
possar
95
17
gateshead
c class
30 year
i have a burstner t660 and all i do is swing the 2 seats to face each the bars under the seat that moves the seat back and forth they practically touch each other then i put a yale lock over the bars then lock them together
