Just ordered mine £38 ebay
YES, BUSBY.Hi I have fitted my disklok to my van and my friend said why don’t I turn my swivel seat around and drill a hole in the runner and padlock it in the turned around position so they won’t be able to sit and drive if they go to steal
It has anybody done this
I don't think that one will fit a lot of seat bases.This one is even cheaper and easier to fit and remove.
Guess which one I have?
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=352818969559
With all those bit on there do you live in a dodgy area?14mm hole drilled in seat base, as Lenny mentioned on another thread the Aguti seat base is a lot thicker than other makes. Similar positioning to Lenny seat is locked at 45 degrees from fully rear wards due to design constraints. Lock allows a degree or two of seat movement max, well pleased. (Hymer DL)View attachment 444430View attachment 444431View attachment 444432View attachment 444433View attachment 444434
Naw very quiet and rural and hope it stays that way, just making sure anyone eyeballing it will need lots of time and a lot of fully charged battery packs for their cordless grinder.With all those bit on there do you live in a dodgy area?
Only if you have the standard Fiat seats, what about Aguti & ISRI seats that a high percentage of Motorhomes no hi are fitted with.
It’s the thickness of the seat base plate which determines what thickness of spacer washer needed under the head of the locking pin. Lenny and I have Dynamic Line Hymers with Aguti seats the plate is 7.5 mm thick so very heavy duty compared to the standard Fiat one so a standard thickness washer was used. With the thinner base a much thicker one is required to prevent any gap so a grinder cannot be used to cut through it by some lowlife.I shall be hopefully fitting my lock in the coming week, can you please explain the difference in thickness and what difference it makes thanks, my seats are Agutti I believe, or Isri
The lock is designed to fit a 10mm disc, the Aguti seat base is 7.5mm thick so you need a 2.5mm thick washer to take up the slack. A standard 14mm washer just happens to be 2.5mm thick just glue it onto the base of the pin with epoxy.I shall be hopefully fitting my lock in the coming week, can you please explain the difference in thickness and what difference it makes thanks, my seats are Agutti I believe, or Isri
Can you get your hand under the swivel, through the front or rear vent cover type thing.....or don’t you have that either?I've looked at all these great suggestions but absolutely none will work with the swivel seat fitted to my 2019 Citroen Relay campervan. Feeling scuppered so far!
I have washers under my Patriot so as to not allow cutting from underneath. I suspect it will just spin with an angle grinder attack. You need the short shank version. The longer version is for use with a chain.
Did you have to drill on the swivel plate or anywhere else . I,m very interested in this device.Liked the idea of the Oxford Patriot motorbike disc lock from earlier on in this thread, so bought and fitted one.
It's great, a doddle to fit, use and store, plus it looks to be pretty well cordless grinder and hammer proof with no access to the 14mm hardened steel pin.
Just worried about Construction & Use Regulations, altering certain things on vehicles is a no no, especially seats , safety belts, steering etc.
As you have to be v
Just one hole in the base of the swivel plate.
I have no concerns and I'm happy that it has compromised the integrity of my seat unit.
You have to make your own mind up on what you feel are the rights and wrongs or repercussions of fitting a Patriot lock as myself and others have done.
I think you'll find you'll need to drill a hole. I used a 90 degree drill attachment (Screwfix do an Eurbauer one at a decent price) to get a good access, started with a 2mm and worked my way upI can't seem to find anywhere to attach the Oxford lock
My seat still rotates to about 90° I tried moving the van on the drive very awkward no way would you be able to drive it any distance.My lock arrived within two days, brilliant service. Drove to site where van is kept to look over the drilling of hole etc and I feel a problem coming on .
An 'A' class Pilote, whichever way I position the seat I still feel it will be possible to drive the van. The original idea was to completely reverse the seat however that makes it soooo easy to simply sit on it !! I have decided that positioning the seat at a position similar to Stewart J is the best option but I am not 100% convinced, difficult to drive but still doable I feel
I came to the same conclusion with my Pilote A class. It would work if you could lock the seat facing backwards, AND found a way of stopping the seat back being lowered, not sure how you would do that. Otherwise in any position you could lower the seat back and sit on it, at least until you had driven it away to somewhere quieter to angle grind the lock off. Alternatively it is only four bolts to lift the seat off and swop it with the passenger one.My lock arrived within two days, brilliant service. Drove to site where van is kept to look over the drilling of hole etc and I feel a problem coming on .
Thanks for the info. How would the Oxford lock fit in the hole?I think you'll find you'll need to drill a hole. I used a 90 degree drill attachment (Screwfix do an Eurbauer one at a decent price) to get a good access, started with a 2mm and worked my way up
