Swivel seat security (2 Viewers)
TerryL
6,189
8,194
North East
Low Profile
Been suggested a few times on here - seems to be a simple security option. Only downsides I can see are 1/ needs a good padlock to thwart bolt cutters and 2/ probably not so good if you need a "quick getaway".
Thinking of doing it myself.
Nov 5, 2013
3,114
98,069
Shropshire
Carthago chic e-line
Since 2013
Oxford Patriot disc lock on ours (y)
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
I would think it’s a good idea. It would be difficult to swing a pair of bolt cutters on a suitably positioned padlock under a seat, if your crafty where you put it. :gum:
Mar 23, 2012
9,577
32,217
sleights
c class
I lock my seat in the rearward facing position with a bike lock. No need to make any alterations to the seat itself. Just pass it through the bottom, up and back through and lock it. Dead simple.
I might try that I started to drill a hole but the plate is really thick and innacessible the bke tock looks like an easy fix
Feb 22, 2011
9,837
20,281
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I've done it and you'd never get bolt cutters near it in the only position it would go.
Also makes it a little fiddly to release with keys as well but is a very effective security method, and cheap to do.
I just need to remember to use it :xgrin:
Feb 9, 2008
8,954
18,710
Corby, Northants
Coach Built
It is! Although I have to get on my knees to thread it through. There is a little movement on the seat after the lock is fitted, maybe between 20 and 40 looking at a clock. However, there is no way it can get anywhere near a position that you could drive the vehicle.
Aug 18, 2011
12,155
18,026
derbys
AUTOSLEEPER SYMBOL
Hi I have fitted my disklok to my van and my friend said why don’t I turn my swivel seat around and drill a hole in the runner and padlock it in the turned around position so they won’t be able to sit and drive if they go to steal
It has anybody done this
Similar ..I lock my driver's seat in position after I have slid it fully forward into the dash..BUSBY.
Feb 2, 2019
1,073
2,537
Norfolk
Pilote G740C
Ive done it and use a closed shackle container lock.....it will be easier for any thief to cut the seat completely out rather than trying to get the lock off. Cheap easy additional piece of security to add to the alarm, tracker, steering lock and clutch claw, not to mention the window locks and fiamma door safes.
Jan 16, 2014
1,343
2,475
Surrey
Rapido 854f
Since 2012
Yup
Drilled a 6mm hole with one of these
And then fitted one of these upside down so hard to pick lock
Amazon product ASIN B075MG4FNQLower the drop down bed, fit the diskloc, set the alarm and set the other secret device and I recon it's not going anywhere without a low lowder
Jan 27, 2018
2,678
2,127
Northampton
Rapido & Bongone
Another fan of the oxford patriot.
In order to take up slack and prevent cutting acess under the body i added washers to the pin under the seat before assembling. Hope thats clear.
Wombles
10,813
11,139
SW England
Van Conversion
A few years now
Liked the idea of the Oxford Patriot motorbike disc lock from earlier on in this thread, so bought and fitted one.
It's great, a doddle to fit, use and store, plus it looks to be pretty well cordless grinder and hammer proof with no access to the 14mm hardened steel pin. (y)
Been thinking about doing that for a while but expensive lock so good to have another confirmation that it works well (y) We have a big padlock at the moment but pretty cumbersome so that does look a neat solution.
Two on Tour
10,371
51,309
Elddis Autoquest 175
Since 2010
Got mine from Amazon for £39.07 which was the best price for new I could find and I now await for some sod to point out where I could have got it cheaper. :LOL:
Amazon product ASIN B00366646E
Jan 27, 2018
2,678
2,127
Northampton
Rapido & Bongone
Best price from
Broken Link Removed
Currently
Was writing this whilst last pos tcame
The best disk lock is the abus granite but £120
Jan 23, 2016
1,899
306,592
Wales
Adria Coral 660SP
25 years
One of my Storage neighbors showed me how he had done it, using a top of the range bike D Lock.
It looks very effective.
Feb 2, 2019
1,073
2,537
Norfolk
Pilote G740C
This is mine using a heavy duty container lock. The gaffer tape is just holding a piece of foam in place so I don't mark the seat base if I accidentally move the seat back while it's still fitted. Proper heavy weight lock specifically designed for shipping containers and not too expensive either.
ManTheVan
1,465
2,791
South Devon, UK
Rapido C class
Yottie convert
Can I ask, did fitting simply involve drilling a 14mm hole?
